Squeek !
Old Aug 11, 2012 | 11:32 AM
TwiZted Biker's Avatar
TwiZted Biker
I stand corrected on the chain drive , glad you found it but be aware once they start the chirp it's a sigh the belt & pulleys are worn , Change time is coming and parts for the older ones are getting harder to get by the day , start looking now and pick stuff as you find it .
Old Aug 11, 2012 | 01:28 PM
mballard's Avatar
mballard
hmm...
good point,,, planning ahead is a great idea..
I will start looking for belts and two gears i suppose.
two more questions:
(1) how do you get that caliper off?
(2) ever use any belt "dressing" ?
thanks
marion..
Old Aug 11, 2012 | 01:36 PM
TwiZted Biker
Originally Posted by mballard
hmm...
two more questions:
thanks
marion..
Try and get the MoCo tranny sprocket , they will have to order it course if they can still get them . The after market front pulleys are cheaper made and the OEM is all steel , was cheaper than the aftermarket stuff if you can believe that .
I'd have to see which caliper you have the memory isn't that photogenic anymore
Hey we need some pics of the bike anyway , shovel **** is mandatory in here hasn't anybody told you yet ?
Old Aug 11, 2012 | 01:51 PM
tjansen's Avatar
tjansen
6th Gear
That must be the first belt drive and last Shovel. Go figure.
Glad that is fixed, now on to the rest of the Gremlins.
You may want to have a look at the straightness of the wheel / axle as JohnnyC suggests. Search Belt tension / axle alignment . This can, 'cant' the wheel and pulley and give you a belt squeak in another month when the clean wears off.
T
Old Aug 11, 2012 | 02:10 PM
Stiggy's Avatar
Stiggy
quote=tjansen;10190752]That must be the first belt drive and last Shovel. Go figure.
T[/quote]
Mine starts to squeak every couple of thousand miles too.
I didn't have any belt dressing when it first happened so out of frustration I took a dab of anti-seize and ran it along the exposed 8 inches or so of the belt, just between the pulley and the belt guard on the outside edge. Just on the side, not on the teeth.
That little bit stops it for a couple of months for me, ( I ride 400 miles a week,) and when it starts to come back it gets another dab on the next weekend cleaning/checkup.
No adverse effects. The belt is original with 114,000 miles on it.
Old Aug 11, 2012 | 04:07 PM
mballard's Avatar
mballard
Default hope this works....
my apologies for not following the rules!
I'm just OLD and forgetful.
She is a really beautiful machine.
Dark and raining here in Carolina today, so the pict in the barn is kinda dark.
the "other" pict was from the prev owner, I think about 5 years ago.
Old Aug 11, 2012 | 04:08 PM
mballard's Avatar
mballard
auburntsts
Jan 17, 2019 12:09 PM
shyy
Apr 15, 2017 01:57 PM
Bearcat1
Sep 15, 2009 09:23 PM
Bearcat1
Sep 15, 2009 01:28 PM
paulinwmass
Oct 3, 2008 08:32 PM
