Sprocket advice
Old Dec 13, 2012 | 02:28 PM
WoodrowWillson's Avatar
WoodrowWillson
Default Sprocket advice
I am thinking about changing from a 22/51 to a 26/51 final drive. Any advise? I have my trany apart right now and I want to change the main drive sprocket to get a little more top end speed. I want to keep the 51 rear spocket for now. I havent been able to find any write ups on a 26/51.
Thanks
John
Old Dec 13, 2012 | 04:16 PM
AlCherry's Avatar
AlCherry
If you can find a 26, you may run into clearance issues with the inner primary. You can attain really good top end with a 23/46 combo. Really, how fast do you want to go? Is your bike mechanically capable for evading high speed pursuit?
Old Dec 13, 2012 | 04:23 PM
Uncle Larry's Avatar
Uncle Larry
"AlCherry" is right on the clearance problems with the front sprocket ... anything over a 24 will definitely cause inner primary case conflicts. I've seen many chew a hole through the inner. Some have riveted a steel piece to act as a "wear buffer" where the chain will contact the inner, but that's really doing some backyard engineering ... I wouldn't go any bigger than a 23 on the front ... and going any bigger is going to make it real hard to ride when you're in town ... Good Luck Brother!
Old Dec 13, 2012 | 05:15 PM
biginchhustler's Avatar
biginchhustler
stock 74 like a FX 22/48 -- 80" 22/47 or 23/48 a big *** bagger 22/49
i had a ole panhead with a 26 on it worse thing ever - it will NEVER get in the power band -- im doing a 74" right now with a S&S "E" and a sifton 414 cam -- custom tig welded exhaust system -- it will have a 22/48
Old Dec 14, 2012 | 08:22 PM
TwiZted Biker's Avatar
TwiZted Biker
Since I'm not gonna type this out a third time in as many weeks check my posts in both these threads and as Al stated you ain't gonna find a 26 they don't make them that I know of and every 25 I've seen has ate the inner primary & starter housing to the point of the starters coming off .
Since you seem set on it the biggest you can go and not eat hard parts is gonna be a 24 and if you do that get a good highend ( $200 ) oring chain and keep it adjusted or you'll be dealing with a trashed and leaking inner primary and chewed off starter housing shortly . Oh yeah better have good shocks too the old ones will let the *** of the bike drop so far the chains gonna slap anyway .
https://www.hdforums.com/forum/shove...flh-trans.html
https://www.hdforums.com/forum/shove...our-speed.html
Bohemian
Shovelhead
41
Jun 15, 2024 06:22 PM
Pichilingo
Shovelhead
16
May 21, 2013 07:50 AM
flh04087
Jun 26, 2012 03:39 PM
kswan
Shovelhead
Mar 23, 2012 11:37 AM
graves1
May 11, 2010 08:18 PM
