High test gas
Old Jun 11, 2013 | 02:55 PM
sbrmike's Avatar
sbrmike
Default High test gas
I know or at least think that high test gas has higher additives that are somewhat more harmful to Shovelhead components (carbs, gaskets, etc.), but I get usually 40 more miles from a tank of gas on a trip whenusing high test instead of regular. I never did the math to see which was cheaper because the distance advantage was the bigger issue. I usually use some type of ethanol treatment when running high test as well; again this adding to the cost of the high test price.
I mispoke a bit. I get 125 miles per tank with 87 octane and 149 with 93 octane; that is 24 more miles not 40. This is the mileage that I hit Reserve, generally 2.2 - 2.4 gallons.
What are others' experiences and opinons? Mine is a very low compression stock 1984 FXEF engine.
Old Jun 11, 2013 | 05:55 PM
biginchhustler's Avatar
biginchhustler
i use 93 no ethanol -- if your storing the bike for the winter with the ethanol fuel your askinng for problems big time -- find a place that sells 93 no ethanol
roysclockgun
General Topics/Tech Tips
19
May 18, 2017 06:20 AM
Matt0987
May 19, 2013 02:16 PM
GMC4EVR
Jul 16, 2008 09:36 PM
JimS
Road Trips
Jun 1, 2007 07:33 PM
harleybiker
Oct 30, 2005 08:59 PM
