Operating temp
Old Sep 6, 2014 | 07:45 PM
cajun1957a's Avatar
cajun1957a
Default Operating temp
I installed a dipstick with a thermometer in it to monitor the oil temp. I am running 60wt oil in a 74 shovel. I do not have an oil cooler. Temperature read 190 deg F. When this baby is hot it sounds like a typewriter but runs like a bear. When the temp of the oil is around 110 deg F. It is quiet as a mouse except for the pipes. What temp difference will an oil cooler give me and what is a good one to buy that doesn't need a mortgage? What is the normal operating temp of one of these? Today it was about 73 deg F.
Randy
Old Sep 6, 2014 | 09:24 PM
dennisaa's Avatar
dennisaa
Default Bike temp
That temp is low and should be no problem at all. Oil in a Harley can reach 300 degrees F. I have an 04 twinky and it originally ran up to 265F. I replaced the oil with Amsoil 20-50 and lowered the temp. 30 degrees. This was riding in triple digit weather in Nevada. I have an oil pressure gauge on my shovel but not an oil temp.
Old Sep 7, 2014 | 07:42 AM
Rtlang's Avatar
Rtlang
My 76 averages 190-200. I don't think there's any need for a cooler unless you're in a very hot environment all the time. If the oil is too cool, it won't reach where it needs to be.
Old Sep 7, 2014 | 07:03 PM
TwiZted Biker's Avatar
TwiZted Biker
Strickly a twinkie problem with oil that hot a shovel unless somethings bad wrong won't go over 220 even on a 100+ degree days.
OP They get hot tolerances open up and they do run sluggish , ever notice your bike just seems snappier and runs better on colder damp mornings.
Old Dec 28, 2024 | 08:38 PM
Not Grumpy Just Honest's Avatar
6th Gear
Default More oxygen
On cooler mornings with moisture in the air it has more oxygen. That's why any engine runs better in those conditions. I have a front frame conformed V shaped cooler on my FXE and it barely gets much over 160f and I'm in Australia where we get 110+ in the shade days
Old Dec 29, 2024 | 09:09 AM
Racepres's Avatar
Racepres
Default Moisture
Sort of...Moisture don't Compress...so the Compression is Up...Now ya know what a "Skin of Gasket surfaces" can do for you!!
I would Not be comfortable if my oil was Not Hotter than that..Again...Moisture!!
Old Dec 31, 2024 | 04:57 PM
Spanners39's Avatar
Spanners39
I don't run an oil temp or pressure gauge, just an oil light, I am happy if the oil stays in the motor long enough to lube it.
Ndoggct
Milwaukee Eight (M8)
May 9, 2019 06:25 PM
89FLHTC
EVO
Jun 15, 2016 07:44 PM
uwiik
Oct 22, 2013 08:41 AM
russ2yall
Exhaust System Topics
Aug 27, 2009 07:46 PM
custompilot
Oil Archive (no new posts)
11
Apr 30, 2007 11:57 AM
