fork softail FXST 84 - Showa G560
Old May 11, 2026 | 08:45 AM
FXST84's Avatar
FXST84
3rd Gear
Default fork softail FXST 84 - Showa G560
Hi all,
I need an information how to diasassembly the for Showa G560. The left fork it's easy but the right fork not easy. It's very difficult to remove the oil seal and washer that stay between slider and oil seal. Is it possible who the slider sx and slider dx are different ?
many thanks for the support.
R
Old May 11, 2026 | 09:26 AM
eighteight's Avatar
eighteight
Parts diagram shows both sides the same
Old May 11, 2026 | 09:39 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Remove the bolt at the bottom of the slider, remove retaining ring above the seal and yank the fork tube like a slide hammer.
Old May 11, 2026 | 10:22 AM
FXST84's Avatar
FXST84
3rd Gear
thanks Eighteight and Dan89,
I read the manual and I did it. Believe me the slider tube of the DX doesn't come out.
Do you have a g560 showa ?
Old May 11, 2026 | 10:29 AM
Dan89FLSTC's Avatar
Dan89FLSTC
All conventional forks are configured the same way, both sides are the same setup as eighteight said.
Make sure there are no remnants of the retaining ring still in there.
Clean out the area and take a pic.
Old May 11, 2026 | 02:33 PM
FXST84's Avatar
FXST84
3rd Gear
This right fork and we can see the inner of the slider
This the result of  hard work for get out the oil seal
if I try to push out the slider tube, like suggested, the slider tube fits into the bushings
Old Today | 01:37 PM
FXST84's Avatar
FXST84
3rd Gear
Hi
excuse me for I doubt you but like you can see in the picture it's very difficult to realize why the slider tube didn't get out.
the culprit is this washer. It's different of the other slider
thanks a lot for your support.
Old Today | 01:38 PM
FXST84's Avatar
FXST84
3rd Gear
[QUOTE=FXST84;22277602]Hi
heyeng1705
2018+ Softail Models
17
Apr 4, 2024 01:22 PM
FXWG'80
Shovelhead
Mar 25, 2023 09:10 AM
ZBoT
Sep 22, 2021 09:00 AM
JWCFatboy
Dec 8, 2018 12:30 PM
bfrmbama
Dec 2, 2005 08:11 PM
