Dyna Glide ModelsSuper Glide, Super Glide Sport, Super Glide Custom, Dyna Glide Convertible, Super Glide T-Sport, Dyna Glide Police, Dyna Switchback, Low Rider, Street Bob, Fat Bob and Wide Glide.
First time removing and replacing the rear wheel on my, new to me, 2008 Wide Glide. It was quite the hassle having to remove the rear exhaust pipe/muffler to remove the axle.
First Question: I know the manual says to insert the axle from the right side but wonder if anyone reverses the axle to avoid having to remove the exhaust next time around? Or if there is any good reason not to reverse the axle?
Next question: The FSM says the "largest chamfered end" of the spacers should be installed away from the hub... presumably to facilitate inserting the axle. But both ends of my spacers are slightly chamfered and I'm having a hard time deciding which chamfer is the larger. But the spacers also have 2 (or 3) grooves on one end. When the spacers are installed correctly should these grooves go into the hub or away from the hub?
On some bikes flipping the axle will cause the axle to hit the muffler. No other reason not to, other than I suppose in theory the axle could rotate and loosen. I've had the spacers on and off my bike many times, and I don't think it makes any difference which way they go as long as they're in the right space.
When I do the rear tire on my 2008 Fat Bob , I just pull the rear shocks instead of the exhaust , it worked out better for me , but you have to make sure you don't stretch the brake hose ,
Flipping the axle is pretty common to avoid removing the pipe like you are talking about.
Thanks Bubba! Thanks CZ! I appreciate your thoughtful replies. I've decided to install the axle as it was originally, with the nut on the left side, simply because if I reverse the axle, with the nut on the exhaust side, I don't think there'll be enough room for my deep 36mm socket and torque wrench without moving the muffler again anyway.
Interesting point that @Reindeer makes about the spacers. The first time I had them off I looked and looked and could find no difference between either opening, they appear identical. I gather that the 3 rings are there for a reason (my wife's '22 FXBBS still has rings on the spacers), though I don't know what it is. I tried to put them back the way they came off since I know I was the first person to remove mine, but TBH, over the years I know I've forgotten the orientation and they're on the bike in different directions now.
