Neutral
Old Oct 26, 2014 | 05:42 PM
PTSDBob's Avatar
PTSDBob
Default Neutral
First…. make sure it is in first gear.
If not, then you need to learn to turn it off while it is in first.
(HD does not want you 'shifting gears' with the motor off)
Second; sit on bike, front brake engaged (and bike in first), toe under shifter (much easier than using your heel and pushing down. Your toe gives you better feel) you can be running or not to go from 1st to Neutral….
With your toe giving slightly upward pressure, roll bike backward easily about 2 inches…. you will feel the shifter 'release' and as such then be in Neutral.
Old Oct 26, 2014 | 06:30 PM
PPBART's Avatar
PPBART
The '05 Deluxe I used to have would sometimes take several tries to get into N. Current '07 Deluxe never seems to have any problems, hot or cold.
FWIW, I typically will ride the bike into it's shed and shut off with it in gear. Then when it's time for next ride, I sit on the bike, reach down and use fingers to pull shift lever up to N, then back the bike out before cranking.
Probably not a matter of lube, since I've used Formula+ in every Harley I've owned.
Old Oct 26, 2014 | 11:58 PM
MacKenzie001's Avatar
MacKenzie001
Jockey shift FTW lol
Old Oct 27, 2014 | 06:01 AM
Warren9073's Avatar
Warren9073
Originally Posted by ChickinOnaChain
When stop, I kill the engine, then I reach down with my hand to put it in neutral. With my foot, it just takes several tries. With my hand, first try every time.
Old Oct 27, 2014 | 07:10 AM
cocky's Avatar
cocky
My deluxe is much harder to find N than my 04 fxdl. Don't know why?
Old Oct 27, 2014 | 08:40 AM
thomasf59's Avatar
thomasf59
Thats pretty much what I am doing ^^^, except using my heal will give the toe method a try, as I prefer shifting when riding with my toe, the heal shifter to awkward for me, thanks
Tileman2692
Oct 3, 2016 08:33 AM
big_daddy_g
Apr 17, 2015 05:53 AM
northeastconfederate
Jan 31, 2013 10:26 AM
michaelbarry
Mar 30, 2008 08:20 PM
michaelbarry
May 11, 2007 03:07 AM
