I have 2 riding buddies that went down due to failed front wheel bearings. Wrenchy is spot-on, torquing the axle bolts correctly is critical. Additionally, the center spacer between the 2 bearings must be the proper length. If it has any play, excessive preload will be applied to the center of the bearings.
I use All-***** brand wheel bearings and change them every 4th tire change. Cheap insurance.
I had to replace mine around 7500 miles in my '08 Night Train. It had a growl on the rear. I changed all of them out. I went with SKF brand in mine and they are still feeling smooth at a little over 15000. When I do tires in the spring I will swap them out anyway. As others have said, cheap insurance.
