Cell Phone Charging
Old Feb 11, 2015 | 06:08 PM
Ronder's Avatar
Ronder
http://www.digitaltrends.com/mobile/...tery-chargers/
Use when on Bike or anywhere
Old Feb 11, 2015 | 08:33 PM
HedleyLamarr's Avatar
HedleyLamarr
Originally Posted by Sgt_Jim
then i found this one:
Amazon.com: Battery Tender 081-0158 Black Quick Disconnect Plug with USB Charger: Automotive
essentially the same thing, but this one works very nicely. There's reports that say Don't leave it plugged in if you don't have to because it'll drain your bike's battery. I haven't tried, and i'm not going to test it..
+1 on the Battery Tender version. It's a solid piece. I got mine on eBay for 9 bucks and free shipping
Old Feb 11, 2015 | 09:06 PM
Str8six's Avatar
Str8six
Am I the only one that uses riding as an excuse to NOT have my phone with me?
Old Feb 11, 2015 | 10:42 PM
HedleyLamarr
No, but 1000 miles from home and camping, it's nice to be able to not have a dead battery
Old Feb 14, 2015 | 04:38 PM
MachU's Avatar
MachU
this is what I've been using for a few years now.
http://www.optimate1.com/usb
The 100 version
Old Feb 17, 2015 | 02:15 PM
Newfoundlandsoftail's Avatar
Newfoundlandsoftail
I installed an auxiliary power port with saddle bag mount on my 03 Heritage this past summer before heading on a road trip and it worked great. It plugs into the battery tender plugin and you have to drill a small hole in the backside of the saddle bag for the wire to pass through I got it from HD, Part #69200091 http://accessories.harley-davidson.c...addlebag-mount
Old Feb 21, 2015 | 12:16 AM
CVO2015's Avatar
CVO2015
Default USB Dash mountable or beg mountable charging port
iSimple 5 Volt USB Power Oulet Dash Mountable
You will need the accessory pigtail so you don't have to cut into your harness. It will charge a phone but it cannot keep up if you are planning on using it for a GPS or listing to music all day. I mounted mine in the bag just have the wire draped over the top of the bag under the lid. Also installed one in some hard bags too for a friend and they charge 2 Iphones at the same time. I don't like the charging adapter simply because I don't like wire clutter.
Old Feb 21, 2015 | 08:58 AM
RLTW79's Avatar
RLTW79
5th Gear
I bought the BurnsMoto waterproof USB port and installed it inside the nacelle on my FB Lo. Wired it to the yellow wire in the headlight to get switched power (no power if you hit your high beams). Have a RAM mount centered on my bars and run the usb cable for phone or GPS up thru the hole in the plate. Works great, not visible. Use a pigtail with cig adapter for battery tender. Used a 6' extension and ran the cable from the battery down to the frame and up to the front of the bike. Zip tied the adapter end so it is pointed down and can be covered. Gives me second power source (not switched) and easy to hook up the tender even if the motor & pipes are still hot. Got some small diameter rubber hose from HD, split it open and stuffed the cable inside. Used black zip ties to attach to the inside of the frame to prevent damage from road debris.
Old Feb 21, 2015 | 12:06 PM
Scott Moore's Avatar
Scott Moore
2nd Gear
This is what I did. I got a plug that plugs into the battery tender plug. Then I mounted a "side-wall mount" cigarette style DC plug to the rear wall near the top front of my saddle bag. Then I cut the power supply plug wires to the length I needed and soldered/shrink wrapped the battery tender plug wires to it. Now I have a DC power supply for anything right in my saddle bag.
Since I travel across country a few times a year, I use my phone as both my GPS and my blue-tooth MP3 player but the battery goes dead after about 2 hours. I tried a few USB plugs that plug into a cigarette lighter but most do not keep the phone charging faster than it drains.
Then I found that you must have a USB plug that puts out 2 or 2.1 Amps. Most all of them , including HD's plug, only puts out 1 or 1.2 Amps and that takes for ever to charge your devices up and will not keep up with the drain of power by using the GPS, Blue-tooth and texting while going down the highway on your bike. (I know I shouldn't but...).
I then ran a long USB cable from the plug in my saddle bag, under the seat and under the gas tank all the way to the front where I have it strapped to my handlebar risers. Then I use an 8" power cord to plug into my phone or blue-tooth headset when charging is needed. Works great.
Old Feb 21, 2015 | 06:40 PM
PTSDBob's Avatar
PTSDBob
Default my solution...
http://www.amazon.com/gp/product/B00MG9VVW4/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1 http://www.amazon.com/gp/product/B00MG9VVW4/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
I can charge/use as I move; will re-charge from empty 3 times; can become charged 110, or batt connection.
marcocast
Electrical/Lighting/Alarm
May 11, 2016 11:16 AM
CasaWolves
Mar 8, 2010 11:17 PM
JamesDean
Dec 29, 2008 07:20 AM
docker
VRSC Models
Aug 7, 2006 02:33 AM
nasumi2002
Jan 30, 2006 01:48 PM
