Breakout wheel change problems
Old Jun 8, 2015 | 09:35 PM
Jersey Drew's Avatar
Jersey Drew
i think if you use all the standard BO spacers and bearings you will have no issues. i think the fact you are trying to use the abs (CVO) parts may be the issue. the only other things i can think of is... is the brake rotor fully seated on the wheel? and maybe the CVO uses a slightly larger diameter rotor. the last two are highly doubtful even in my mind. i think the CVO uses different size spacers for things because of the ABS. what bearings are in the wheels right now? you say you have pressed in both.
Originally Posted by wedgemoose
Just saw this. I have non abs ones in now. I think the first time they were abs bearings but can't remember which ones I ordered way back. Took a while to get everything. Over a year! But I used non abs and rotor fits in caliper bracket perfect . not hitting or scraping it. Sounf is from sprocket side. Sounds like coming from hub behind sprocket.
Thanks again. I was just wondering what belt rubbing sounded like. Never heard it before. Wondering if my attachment could be belt hitting swing arm. It is real close. And don't remember where it was before all this.
ok that answers me previous question. now use all the stock non chrome non CVO spacers and see what happens.
Old Jun 9, 2015 | 06:12 AM
Warp Factor's Avatar
Warp Factor
Originally Posted by Alain
I have cvo breakout wheels on my rocker. My rocker is not abs, li don't know if abs bearings are different than non abs.
Alain, how are those clipons going for ya?
Old Jun 9, 2015 | 10:23 AM
Alain's Avatar
Alain
Good luck dude. I'm super curious to see what this issue turns out to be.
Hey warp, clip ons are a blast to drive. Not as uncomfortable as they look. Leaning into turns is an amazing experience. Because of the seating position it feels like I'm flying into and through the turn. I get to put my knee out and hang off the side of the bike while making a turn.
Old Jun 9, 2015 | 10:49 AM
wedgemoose's Avatar
wedgemoose
Right now I have NON-ABS bearing in it. I have the CVO rotor also. I bought everything for the rear to make it CVO style. Rotor, sprocket, brake pads, CVO spacer(the one chrome one they use-which is exact same width as the stock one I took out). it should work in my mind. I have non ABS bearing in it. I have the Non ABS spacer from my original set up. Unless the CVO rim is made differently it should theoretically work. I think the belt is too close to frame(which means spacer problem) or I have bad bearings or they were pressed in wrong(but the guy that did them is awesome). but I don't know how close the belt was before the change. should of checked. But wasn't expecting this to happen. And another thing is the front is perfect. Why would my stock NON-ABS spacer work perfect up front but not in the rear??? I always have this type luck thanks for the help
That's tonight Jersey. There is only one. Sprocket side. And it is the EXACT same width as the fancy Chrome CVO one. But I am still trying it tonight. You never know.
First off thanks all!!!!! You guys are the best. Here are some pic's just in case any of you see something I don't.
Attached Thumbnails Breakout wheel change problems-0608152238a-medium-.jpg   Breakout wheel change problems-0608152238c-medium-.jpg   Breakout wheel change problems-0608152238e-medium-.jpg   Breakout wheel change problems-0608152239a-medium-.jpg   Breakout wheel change problems-0608152237-medium-.jpg
Old Jun 9, 2015 | 11:28 AM
mkenkel's Avatar
mkenkel
just a guess,but ck to make sure that your lower belt guard is clearing the pulley. I installed one wrong once and it made a hell of a scraping noise as the wheel turned.
Old Jun 9, 2015 | 11:55 AM
Jersey Drew
i will try to look at mine tonight when i get home and take some pics for you.
1004ron's Avatar
1004ron
Photos 1 & 5 would be good if the rotor alignment with the calliper holder was in focus at that area.
Old Jun 9, 2015 | 12:41 PM
Jersey Drew
that doesn't look like the stock axel either. mine has a mountain of a nut on the left side that requires a 3/4 inch hex.
Old Jun 9, 2015 | 12:53 PM
wedgemoose's Avatar
wedgemoose
I have them both off. That was my thought at first. But no luck. that would of been nice and easy.
I know. Almost impossible to get. I tried ten times. I could not get the phone in there at the right angle to get a good pic. Hard to see also. but there is clearance on both sides. It's not hitting the bracket. it has flex and I flex it both ways to test.
Maybe I'll try for a better pic tonight
Yes Jersey you are correct. I got the CVO one so I could finally use Axle nut covers.(it comes with special washers that allows the covers to screw to) That looks the same also. Same length and diameter and all that stuff. But maybe that could be it? I'll try that tonight also.
And thanks for looking at yours tonight for me. I owe ya.
Here is what the poor thing looked like once I was done and before the test rides. I love the look. That's why I don't want to give up. I'm thinking to maybe buy the CVO abs sensor(and cut the wires and use as a dummy sensor) but I would also need the Caliper bracket because it has a hole in it for the abs sensor to align into. But first I'm going to measure everything off my stock rim to see if I can figure out what is the problem before spending another couple hundred. And I would also have to put abs bearings in again.
Old Jun 9, 2015 | 01:15 PM
Jersey Drew
and thanks for looking at your tonight for me. I owe ya.
thinking about it, it shouldn't affect the situation at all.
and that sure is a purdy bike!
