Power Vision Question
Old Jun 10, 2015 | 05:50 PM
Berick's Avatar
Berick
Originally Posted by Valdemar
If you are running without baffle or baffle non very restrictive,it´s normal.
I've got a Vance & Hines 2 into 1 Big Radius and I've done nothing to the pipes.
Old Jun 10, 2015 | 05:51 PM
hattitude's Avatar
hattitude
Originally Posted by Berick
Are you guys still getting decel popping through your exhaust even after being tuned? Mine pops even after 2 rounds of the "auto-tune"..... Is it normal on these bikes to have a bit of popping?
Or.. you have an exhaust leak
Or.. you need to change the AFR just a tad in the decel area
if your exhaust is not without a baffle, and you check for and have no exhaust leaks, then send your autotuned map to Fuelmoto. Tell them you have decel popping. They should be able to fix you right up...
Old Jun 11, 2015 | 12:21 AM
Gommee's Avatar
Gommee
Devil's Advocate
Check this thread out, running the update as suggested helped my tuning process. There may be tables that are not showing up for you.
https://www.hdforums.com/forum/ignit...2-sensors.html
Old Aug 25, 2015 | 07:02 PM
Berick's Avatar
Berick
Just a quick update.....
I've read a lot of threads regarding the Auto Tune for the Power Vision and a lot of fellas are saying to run it 3 or 4 times and that's all you need.
I had to run the Auto Tune function 8 times before the bike would run better. It ran like crap after the first 4 attempts and began to get better after the 7th attempt. I am satisfied now after the 8th attempt and will keep it as is for the time being. It finally got rid of most of the "decel-pop" I had in my exhaust. I can still get it to pop but it's way better than it was initially.
Just thought I'd let the rest of you fellas know that it may take a few kicks at the cat to get the tuning down.
Old Aug 25, 2015 | 11:01 PM
Da-Rza 21's Avatar
Da-Rza 21
getting ready to install my powervision, do you leave the monitor on during auto tune sessions?...was thinking of mounting mine somewhere on the bars for the extra guages due to that i have very limited info on my bo guage
Old Aug 26, 2015 | 02:55 AM
Gommee's Avatar
Gommee
Devil's Advocate
Yes, you require the PV connected when doing your AT sessions. After you are satisfied with your tune, you can remove it once you flash the final tune.
The extra gauges are a nice add on.
Old Aug 26, 2015 | 10:50 AM
Da-Rza 21's Avatar
Da-Rza 21
thanks man!
koolbreez
Feb 19, 2018 01:26 PM
DavidStiebel
Nov 7, 2016 12:43 PM
DavidStiebel
The Dyno Room
Nov 7, 2016 09:54 AM
SnoRider
Sep 30, 2015 06:57 AM
zwildman
Jan 11, 2013 07:37 PM
