Turn signal conundrum
Old Feb 23, 2016 | 04:13 PM
scatgo's Avatar
scatgo
5th Gear
Default Turn signal conundrum
I got these
Amazon.com: Astra Depot 2pcs Red Maltese Cross LED Marker Turn Signal Light For Harley Davidson Honda Suzuki Kawasaki Yamaha Custom Motorcycle: Automotive Amazon.com: Astra Depot 2pcs Red Maltese Cross LED Marker Turn Signal Light For Harley Davidson Honda Suzuki Kawasaki Yamaha Custom Motorcycle: Automotive
but for the life of me I ant think how to have running light that will flash with this setup. When I put power to the wires it light. When I put power to the two wires and one gose through the flasher it will flash. How do you get both? Got these flashers
Amazon.com: AUDEW 2-Pin Speed Adjustable Motorcycle Motorbike Turn Signal LED Flasher Relay NEW: Automotive Amazon.com: AUDEW 2-Pin Speed Adjustable Motorcycle Motorbike Turn Signal LED Flasher Relay NEW: Automotive
Old Feb 23, 2016 | 04:27 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Running lights flashing? Running lights are not the lights that would flash, the turn signal element of the bulb will be the one that flashes.
What exactly are you trying to accomplish?
Old Feb 23, 2016 | 04:35 PM
scatgo's Avatar
scatgo
5th Gear
Ok I got the led turn signals that have two wires I would like the turn signals to stay on till I hit and hold the turn signal button to make them flash. I am going to have to wire from scratch.
Old Feb 23, 2016 | 04:53 PM
RANGER73's Avatar
RANGER73
Wrong lights. you need 3 wires unless the stems are self grounding. But this is old school tech. and most newer lights use a wire for grounding.
Old Feb 23, 2016 | 05:01 PM
scatgo's Avatar
scatgo
5th Gear
Fist thing i checked was to see if the stems grounded. No good. I can make it work. Just came up with the idea of useing a five pin relay. When I hit the turn signal button it will switch from + straight to turn signal to + to the flasher relay then light. That should work. Just going to be a pain in the ***.
Old Feb 23, 2016 | 05:56 PM
LA_Dog's Avatar
LA_Dog
Yeh the relay will work but ideally it should have been a three wire light.
The tail lights on my Breakout are two wire, but the change from running light to flashing turn signal or brake is handled by the BCM control module. My front lights are three wire, although I removed them and replaced with tiny, ultra bright 2-wire leds for turn signal only. Good luck with the project-
Old Feb 23, 2016 | 06:00 PM
scatgo's Avatar
scatgo
5th Gear
Thanks
Old Feb 23, 2016 | 06:28 PM
Cygnusx51's Avatar
Cygnusx51
Wait....so if you want your rear signals to be on while riding and then flash when turning, you just need to get a run/turn/brake module. Many people recommend the one made by Badlands....
If you're wiring these up on an older bike where the run/turn/brake module won't work, couldn't you use an LED intensifier converter? This will make a 2 wire light into a 3 wire giving you low light (running), high light (turn signals) and ground.
http://jokermachine.com/products/bad...rter-4173.html
Is this a true custom mockup or are you just adding something to a bike that's already wired?
Old Mar 24, 2016 | 09:17 PM
scatgo's Avatar
scatgo
5th Gear
100% custom. Got it done with a with a five pin relay.
Thanks
Mikula
Electrical/Lighting/Alarm
Feb 15, 2016 05:09 PM
Xskyfallx
Oct 14, 2015 10:04 PM
Patrick1979
Jul 9, 2015 09:19 PM
voudoujoe
Apr 13, 2011 08:03 AM
fxdbike
General Topics/Tech Tips
Sep 9, 2004 01:49 PM
