wider tire for nighttrain
Old May 17, 2007 | 09:31 PM
mike01844's Avatar
mike01844
Default wider tire for nighttrain
does anyone know the widest tire i can use on a stock 2004 night train
Old May 18, 2007 | 05:27 AM
1CrazyTrain's Avatar
1CrazyTrain
Default RE: wider tire for nighttrain
With a custom wheel 18x5.5 and a 160/60-18 or 17x4.5 with a 160/70-17. With proper spaceing you will be ok.
Old May 19, 2007 | 06:03 PM
NYNickET's Avatar
NYNickET
prob a silly question. . if you chance the swing are u could pretty much put whatever u want on it yes?
Old May 19, 2007 | 06:40 PM
20NightTrain03's Avatar
20NightTrain03
ORIGINAL: NYNickET
nope, belt location/spacing plays a bigger a bigger role
Old May 19, 2007 | 08:49 PM
02softail's Avatar
02softail
i was talking to a guy with a 2001 fxst who said he put a 160 on with no changes.didn't believe him until i actully saw the bike and hedid have a 160 on it..
Old May 20, 2007 | 05:44 AM
chopperhead2's Avatar
chopperhead2
at my old shop we did a 180 or 200 tire on a 2004 fatboy. We used the stock swingarm ifI remember right. It was a DM customs kit.
Old May 20, 2007 | 11:08 AM
jchildress21's Avatar
jchildress21
If you're willing to go to a 9" fender, andcut off your fender struts, you can go with a 180 tire, no problem. I have a 200 on mine, but requires a little more work. If you go to the 2006 narrow pulley, then the 200 is a direct bolt up. You just change the belt, pulley, tire and wheel.
Old May 20, 2007 | 01:59 PM
chopperhead2
cutting the fender struts isn`t required. when we did the kit we did not want to cut the struts because wewere building this to put on our show room and didn`t want any liability issues with cutting the frame.
Old May 20, 2007 | 02:15 PM
nitetrain's Avatar
nitetrain
Chopperhead2,
I've been looking at that same kit for a year now. How is it to install, pretty straight foward, and is there any cutting required?
Old May 20, 2007 | 02:21 PM
1CrazyTrain
ORIGINAL: chopperhead2
Cutting the fender struts isn`t required.
180 or 200 tire on a 2004 fatboy. Wow, without cutting the fender struts.I would need to see some pictures for this one!!!
