Dyna vs Softail Clutch
Old May 23, 2016 | 10:28 PM
Gommee's Avatar
Gommee
Devil's Advocate
My Clutch is stiff, extremely stiff. It is not the cable lube, nor is it the adjustment, but rather the clutch pressure spring. I pulled the stock spring and put the SE HD clutch spring in. I like it this stiff and the positive clutch engagement. I have a new Burley Easy clutch adapter sitting in the drawer. I had the variable clutch on it, but removed it. I like just the SE HD clutch plate alone the best.
Old May 24, 2016 | 08:15 AM
nhrider1's Avatar
nhrider1
Originally Posted by Kburgad
06 dynas have the ez clutch ramp setup from the factory. 06 and earlier softail didn't my 04 train clutch was stiff compared 2 my buddies 08 glide and his dad's 06 dyna. Burly easyboy lite clutch took care of that. Changes the fulcrum angle of the ramp pull.
The EZ Clutch arm is available from HD and will drop right in. After you clean and lube the cable and adjust the clutch consider changing to the EZ clutch.
I did it on my 2005 Deluxe and it's considerably lighter and very smooth.
HD P/N is 36808-05 it comes with a clutch spring (don't think I used it though).
P/N on the Arm is 25605-00A
Old May 24, 2016 | 09:38 AM
xfirecat's Avatar
xfirecat
6th Gear
Sounds like the ramp angle will make it a little smoother. Its not that bad just different. Inner and Outer ramps are reasonable for Harley parts. If the clutch was smoother maybe I could leave the original spring and just change ramps. Not a big job.
X90
Oct 3, 2017 09:08 PM
Matt0987
Oct 5, 2014 04:07 AM
KingPinVinny
EVO
Sep 8, 2011 08:29 PM
bikecop40
May 1, 2008 10:36 PM
KBFXDLI
Apr 28, 2006 12:44 PM
