Chrome Toolbox for 2016 Heritage?
Old Jun 26, 2016 | 04:00 PM
Biggerfoot's Avatar
Biggerfoot
Default Chrome Toolbox for 2016 Heritage?
I am trying to find a chrome toolbox that will fit on a 2016 Heritage.
I have the 64937-00A from a 2006 and it lists it does not fit: http://www.harley-davidson.com/store...-12-6493700--1
The 64230-08 does fit some of the 2016 models but not the Heritage: http://www.harley-davidson.com/store...-12-6423008--1
Has any found a bracket or if there is some modification needed for one to fit?
Thanks
Old Jun 26, 2016 | 05:38 PM
Bone Doc's Avatar
Bone Doc
I had the same problem with my 2012 Heritage.
The reason the 64937-00A doesn't fit is because the spacing of the two bolts on the fender rail is different and Harley does not make a bracket for the new spacing. Also, the bracket is supposed to fit underneath the fender rail but it won't work that way because the chrome part of the fender rail has a lip that fits over the steel frame. So the bracket fits over the fender rail.
Even so, the 64937-00A will mount. It has been secure for 4 years now with only two of three mounting bolts. It's very inconspicuous since it is chrome on chrome. Here is a picture:
I imagine it is the same for the left side toolbox but I can't mount that because of the true duals.
Old Jun 26, 2016 | 06:53 PM
Biggerfoot's Avatar
Biggerfoot
Thanks. This is helpful.
Did you still need the additional footpeg extension kit (49352-00) or the saddlebag relocation kit (90238-00) still?
Old Jun 26, 2016 | 08:39 PM
Bone Doc's Avatar
Bone Doc
I didn't need the footpeg extension kit and did require the saddlebag relocation kit both because I have passenger footboards instead of foot pegs.
I would say that if the instructions say you require additional parts/kits with your particular setup than you probably do.
Best of luck. I hope it works for you. Ride safe.
Old Jul 5, 2016 | 04:18 PM
Biggerfoot's Avatar
Biggerfoot
I am finally getting to the point to give this a try.
It looks like it will fit like yours even though the new 2016 bag set-up does not require the relocation brackets for the footrests.
Did you use a spacer or anything to prevent the toolbox bracket from rubbing up against the chrome on the fender rail? It looks like it is setting a little back off of the rail in the photo.
Thanks!
Old Jul 5, 2016 | 05:05 PM
Bone Doc's Avatar
Bone Doc
Thanks!
No. The toolbox bracket is bolted directly to the chrome fender rail. It may look that way due to a shadow from the seat.
Old Jul 8, 2016 | 08:49 AM
Biggerfoot's Avatar
Biggerfoot
While installing new saddlebag guards and passenger footrest, I thought I would see if the toolbox would fit on a 2016.
They did redesign the saddlebags and no relocation mount was needed for the footrests so things are different from my 2006.
Unfortunately, it will not work with a foot peg or floorboard mount. It is hard to tell in the image, but there is about 1/2-3/4" space from the frame mount to where the tool box would mount. If just running solo, a spacer probably would do the trick.
Hopefully they will release a toolbox or mount for the 2016 as I think it looks bare and I really used it!
Thanks for the help.
Old Jul 8, 2016 | 09:59 AM
Bone Doc's Avatar
Bone Doc
If I recall correctly, my toolbox bracket also had a space at the footboard/peg mount. I certainly don't remember how much. But, there should be enough flex in the bracket to push it up against the frame and bolt it in. It may cause a slight angle in the toolbox but it isn't noticeable.
Don't hold your breath for them to release a bracket or toolbox that works with your 2016. They haven't yet for the 2012.
Old Jul 8, 2016 | 10:13 AM
Biggerfoot's Avatar
Biggerfoot
Out of all of the models, I think the Heritage calls for a toolbox so it is surprising to learn even the 2012 does not have one!
Old Jul 8, 2016 | 10:45 AM
Bone Doc's Avatar
Bone Doc
Out of all of the models, I think the Heritage call for a toolbox so it is surprising to learn even the 2012 does not have one!
I agree. Reality says that there is no way to keep up with what parts will no longer fit with every redesign on every model. They have more important things to focus on.
Post back if you end up installing it.
Johnny5455
May 6, 2026 02:24 AM
Cobra6
Softail Parts
Apr 11, 2018 11:43 PM
Puttnik
Softail Parts
Jun 6, 2017 12:51 PM
Softail HA
Mar 30, 2013 04:09 PM
Harley03joe
Apr 20, 2008 05:42 PM
