Apes with ABS....which line
Old Oct 13, 2016 | 08:00 PM
Jimmy55TX's Avatar
Jimmy55TX
Default Apes with ABS....which line
If anyone reading has put taller bars on a Softail / Heritage with ABS which style brake line did you use? I have one with a 25 degree fitting to the masrer cyclinder and it looks like crap. How did you route the line? Pics would be great.
Old Oct 14, 2016 | 11:07 AM
apocalypsesrt's Avatar
apocalypsesrt
5th Gear
I just bought the kit with ABS for my 2014 from Carlini.. I will post up a pic when it gets here.
Old Oct 14, 2016 | 07:49 PM
FLS103's Avatar
FLS103
I used a universal brake line from Goodridge. Ended up with a 35 deg banjo fitting on the top side and a 180 deg straight fitting on the bottom side. The universal lines have no fittings, you have to purchase the fittings separately.
Old Oct 15, 2016 | 06:30 PM
Misbehaven's Avatar
Misbehaven
Did the same with Magnum Shielding universal line.
Old Oct 17, 2016 | 05:52 PM
Jimmy55TX's Avatar
Jimmy55TX
That's what I have now and it looks like crap at the master cylinder. Ordered another line with a 90 at the mc.
Thanks
Old Oct 17, 2016 | 06:22 PM
FLS103's Avatar
FLS103
Thanks
Evidently you mis-typed your original post because it says you have a 25° not a 35°.
The 35° fitting makes my brake line flow into the same angle as my throttle/idle cables. I don't think it looks like crap, but I guess looks are subjective.
Thanks
Old Oct 17, 2016 | 06:43 PM
Tampa Fatboy's Avatar
Tampa Fatboy
Have you taken time and looked at what the Deluxe ABS brake line routing is? Are you aware you that you have the brake line junction under the neck, that bolt needs backed out and a lil lube put on it occasionally. There are several manufacturers that provide these brake lines. I like HD's Diamondbacks, but, for less you can find the same quality.
EDIT: To me the ABS on a Deluxe is overkill, when it goes out or needs some high price BS from HD, trust me, it's going to be history.
Old Oct 20, 2016 | 12:49 PM
Jimmy55TX's Avatar
Jimmy55TX
Thanks
I have TBW
LA_Dog
Mar 25, 2015 01:39 AM
semifan1
Mar 7, 2014 11:23 PM
X6x6x7x
Nov 20, 2013 06:22 PM
HDJIM1158
Feb 5, 2013 02:57 AM
caleb7mm
Mar 22, 2008 09:05 AM
