No Spark??
Old Mar 16, 2017 | 06:37 AM
Jackie Paper's Avatar
Jackie Paper
I am pretty sure a 2001 has a crank sensor just to right of the end of the oil filter. On the left side of the crank case. It may be that. If it does not get a signal, it ECM will not tell it to fire.
Old Apr 13, 2017 | 07:04 PM
HDman2's Avatar
HDman2
1st Gear
I have the same issue on a 2000 Heritage carb with a stage 1 kit! Anyone come up with a fix? I rode 200 miles, ran perfect. Parked it for 5 days, hit the starter and NO SPARK! Crank Sensor?
Old Apr 14, 2017 | 06:27 PM
HDman2's Avatar
HDman2
1st Gear
UPDATE I followed the instructions in the HD Bible Manual "the big one" and tested the electrical system. Skip the bull **** guys and do it all from the end to save yourself a couple hours and test the Crank Position Sensor first! Mine was way under specs. Bought a new S&S sensor and WAM, fired right up!
Old Apr 14, 2017 | 06:54 PM
PeterV's Avatar
PeterV
2001? Cam position sensor..
Old Apr 14, 2017 | 08:09 PM
HDman2's Avatar
HDman2
1st Gear
Not sure what your ? is!
Old Apr 14, 2017 | 08:44 PM
thunderfootblue's Avatar
thunderfootblue
Originally Posted by crestwood
Last Saturday I ohmed out most of the ignition circuit.
Did that include the plug wires? As I recall they should run something like 5-8k ohm per 1' of plug wire. Mine read nil. Replaced them and it started.
Old Apr 14, 2017 | 09:07 PM
PeterV's Avatar
PeterV
One more thing to check.
Old Apr 15, 2017 | 05:46 AM
HDman2's Avatar
HDman2
1st Gear
Yes sir! Cam sensor is another! TY!
IMO the most likely to go is the Camshaft Position Sensor. That's the last thing the book had me check and what I had suspected to be wrong. Chatter on the forums has it saying early builds had an issue..........Had I skipped all the other inspections and jumped to the end I would have save a lot of time. Just say'n
crestwood
Electrical/Lighting/Alarm
14
May 27, 2024 02:48 PM
mckelcd
Jun 10, 2017 08:58 PM
crestwood
Mar 5, 2017 05:56 PM
bigtwinroadking
14
Dec 1, 2012 01:50 PM
jcsportster
Ironhead
May 16, 2008 08:56 AM
