STEALTH batwing fairing
Old Jun 26, 2017 | 08:29 PM
  #51
cuda67bnl's Avatar
cuda67bnl
They're showing in stock again, if you're still interested. I'm buying another, but gonna wait a couple weeks.
Old Jun 27, 2017 | 02:57 PM
  #52
DieselDoc103's Avatar
DieselDoc103
ill check em out!
Old Jun 30, 2017 | 12:22 PM
  #53
Aaron Stanford's Avatar
Aaron Stanford
Stage II
Is there a plate or something that the radio mounts to or do you have to fab your own mount set up? Is there a install kit out there for the head unit, more than the marine cover? I'm in debate of the stealth and another I found on eBay from a place called motorcycle fairings and more, Look at this on eBay http://www.ebay.com/itm/253015454838. Wasn't sure how much little stuff a guy would run into needing in the install.
Old Jun 30, 2017 | 05:27 PM
  #54
cuda67bnl's Avatar
cuda67bnl
The stealth comes with the radio hole cut out to fit a DIN mount. It will have to be trimmed slightly bigger for a marine cover. I added a little brace to support the back of the head unit. You don't have to use a cover, but I prefer to. You shouldn't need anything special for the install other than speaker wire, power wires, connectors, etc. and a little piece of metal for a rear brace. My Woody's fairing uses a simple $5 dipole antenna, and that's what I just bought for this one. I always listen to an iPod anyway though.
The fairing you posted apears to come in primer rather than gel coat. That may not matter to you if you're planning to paint anyway. The other main differences are that the one you posted looks to take a 5 hole windshield, and the speaker openings protrude out from the fairing.
Old Jun 30, 2017 | 09:30 PM
  #55
Aaron Stanford
Stage II
Yeah, I'm a body and paint tech, so as long as the glass or abs is good and solid, a little extra trimming and priming wouldn't kill me, probably prefer it anyway, lol. The 5 holes for the windshield and speaker pockets is what caught my eye. I feel like it'll be a better seal around the windshield and pockets will give a little more depth to the piece. I figured it'd be pretty basic, but haven't seen one up close in person and wasn't real sure there.
Old Mar 12, 2018 | 03:05 PM
  #56
Satan's Avatar
Satan
Default Problem
Has anyone had a problem with the USA Stealth Batwing rubbing on the headlight Bezel? I have a Switchback and mine is rubbing and a real tight fit.
Old Mar 12, 2018 | 08:55 PM
  #57
KrakkyDoo's Avatar
KrakkyDoo
mine rubs my aux light on the right side. I have a deluxe. Very hard for things to be perfect when you are talking about aftermarket parts, especially the cheapest option available. There is a spot on my fairing where the paint is gone because of the light, a little sharper marker touch up and it's good enough for me.
Old Mar 19, 2018 | 03:23 PM
  #58
Satan's Avatar
Satan
Right on and Thank you Sir!
justine120
Oct 17, 2014 10:08 AM
wildrooster
Mar 7, 2012 11:36 AM
rsarno
Dec 21, 2011 04:20 PM
Buggy teeth
Jan 2, 2011 04:08 PM
Mike
Nov 17, 2009 09:08 PM
