When installing new rotors change or keep brake pads.
Old Jun 20, 2017 | 06:09 PM
Redrodyankneck's Avatar
Redrodyankneck
Default When installing new rotors change or keep brake pads.
I'm installing new wheels and rotors front and rear, on my 2015 Heritage. My brake pads have 7,000 miles on them and are HD OEM pads.
Is it best to install new brake pads or best to use the old ones?
Old Jun 20, 2017 | 06:10 PM
Yamaharley's Avatar
Yamaharley
New pads for sure. This way the new pads and new rotor learn to get along.
jkinner's Avatar
jkinner
New ones.
Old Jun 20, 2017 | 06:16 PM
TriGeezer's Avatar
TriGeezer
The old pads will take a set to match the old rotor. So, when you put on the new rotor, the old pads will not have full contact.
Old Jun 20, 2017 | 06:17 PM
eichacsj's Avatar
eichacsj
My OEM pads only lasted 9k and I noticed when I lost brake peddle all at once, so change them.
Old Jun 20, 2017 | 07:46 PM
Scott B.'s Avatar
Scott B.
New and upgrade while you are at it.
Old Jun 20, 2017 | 08:25 PM
Redrodyankneck
Upgrading is what I would like to do but EBC doesn't make front a semi slintered and Lyndall doesn't make the fronts either for the 2015 FLSTC. Lyndall just released an 8181 front pad but it is not in full distribution.
Rears are available from Lyndall and EBC as they did not change in 2015.
2014 is 2 piston caliper 2015 is 4 piston.
Old Jun 21, 2017 | 02:22 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
New rotors, new pads. It's a no-brainer dude!
Old Jun 21, 2017 | 06:19 AM
Redrodyankneck
I thought it was a no brainer too until I researched the subject.
How about some part numbers for composite pads for the front brakes of the 2015? This too should be a no brainer but I can't find any, only sintered.
Old Jun 21, 2017 | 05:55 PM
Redrodyankneck
Just to follow up,
I ended up finding the only pair of non sintered pads I could find anywhere. They are a new product for Lyndall and I got the last pair off their shelf, I also and ordered golds for the rear.
The fronts are only made in the extreme version, (I think they call them that because the price is extreme) but unless I went back to sintered I really had no other choice.
