Help with Saddle Bags Install
Old Jul 5, 2017 | 06:27 PM
FL-kruzen's Avatar
FL-kruzen
Question Help with Saddle Bags Install
Hey folks could use your knowledge here. I got a set of Harley Bags off local Craigslist for a deal. The problem I'm having is removing the fender bolts. They are the chrome Hex head that uses an Allen wrench to remove however, they won't let loose. I already stripped one of the Allen heads. I applied some Liquid Wrench to no avail. I don't have a jack to remove the rear wheel. I'm thinking the other end of the bolt is exposed to all the dirt and grime from the rear wheel. I was thinking about putting some heat to it but I have the quick disconnects that are plastic and they will melt for sure. Any ideas?
Thanks
Old Jul 5, 2017 | 07:58 PM
Axis39's Avatar
Axis39
PB Blaster works better than liquid wrench.
You can also try one of those impact drivers... The kind you smack with a hammer.
Old Jul 5, 2017 | 09:23 PM
Bluraven's Avatar
Bluraven
While in the Air Force there wasn't a day that went by that the "Sheet Metal Shop" wouldn't be called to get a stubborn screw out of a B-52 or B-1 Bomber equipment panel.
The first tool out of their bag was always a speed handle.
With a speed handle you can push into the bolt/screw and then turn it at the same time.
It almost works like a slow impact driver.
I never take a screw out of my Heritage without at least loosening it with my speed handle.
I have a 3/8" and a 1/2" drive ones in my toolbox.
https://www.harborfreight.com/38-in-...dle-62700.html
https://www.harborfreight.com/1-2-ha...dle-95992.html
Old Jul 5, 2017 | 09:30 PM
BbyDgital's Avatar
BbyDgital
My fender bolts were on extremely tight as well, especially with the factory loctite. You just need some extra leverage. I ended up using my torque wrench with a torx socket to get them loose. The extra length of the torque wrench gave me the leverage I needed.
Hope this works for you too.
Old Jul 5, 2017 | 10:37 PM
PA1195's Avatar
PA1195
Aren't they T-45 Torx head bolts? Mine are. Allen wrenches will slip of they are Torx.
Old Jul 6, 2017 | 05:35 AM
FL-kruzen's Avatar
FL-kruzen
Now that's a great idea! I do have an impact wrench! Thanks, I will try that.
Old Jul 6, 2017 | 05:43 AM
FL-kruzen's Avatar
FL-kruzen
The forward most bolt is Torx, the rear two are Allen head. Mine has the quick release luggage rack installed on the rear two bolts that are chromed Allen head. Rather small too. Can't get much leverage without them striping. I'll try the impact driver if I can find an Allen head adapter.
Old Jul 6, 2017 | 06:18 AM
TeaRunner's Avatar
TeaRunner
On the stripped one, wrap a piece of rubber band around the head of your tool or use an oscillating saw to cut a Phillips into the head of the bolt.
Old Jul 6, 2017 | 06:33 PM
Bob Z.'s Avatar
Bob Z.
I heard you for them on Mark...post some pics for everyone to see!
Old Jul 6, 2017 | 10:42 PM
PA1195's Avatar
PA1195
Heat will soften thread locker. Hot air, butane, propane torch on low. Look under the fender (mirror?) and see what the exposed threads look like. Apply lube to loosen if corroded.
Having non-torx on accessory fasteners makes economic but little else sense when it comes to removal.
GAry
Marks57
2018+ Softail Models
Jul 26, 2019 06:24 AM
Sorg67
EVO
May 29, 2016 09:19 PM
mark1957222
Oct 17, 2013 03:04 AM
N83
Apr 11, 2013 01:07 AM
rojuwi
Oct 26, 2012 10:53 AM
