Riding in road construction area
Old Jul 10, 2017 | 10:26 PM
balloo's Avatar
balloo
Default Riding in road construction area
Recently I was in an area where they were doing "chip seal" - - this is a process where they spread oil/tar, and then cover with gravel. Sometimes they roll it and even then the gravel flips up when driving over. Other times they just wave traffic through the newly oil and gravel road.
My worry is this small gravel could get into the belt and pulley and cause damage or even cause the belt to break.
What do you folks do in these situations?
On my last trip, I re-routed myself around the area. Fortunately I had a road map with me.
Thanks,
Balloo
Old Jul 10, 2017 | 11:21 PM
TriGeezer's Avatar
TriGeezer
I try to avoid it. Chips in the finish as well.
Old Jul 11, 2017 | 12:34 AM
Prot's Avatar
Prot
Try to avoid it because it is hard to get off like tar.
As long as you have your belt guards in place, you will be fine.
Old Jul 11, 2017 | 01:46 PM
Geoff's Avatar
Geoff
I avoid areas under construction, even if it means going out of my way.
Old Jul 11, 2017 | 02:16 PM
load97's Avatar
load97
I got stuck in it this spring and it definitely screwed up my bikes paint. Plenty of microchips. It was like going through a 100 yard sand storm it was that bad. I couldn't hardly see ****. I've never had it anywhere near as bad as that before. If there wasn't a truck and I think an 18 wheeler ahead of me it probably wouldn't have been so bad.
Old Jul 11, 2017 | 02:51 PM
jam436's Avatar
jam436
Thanks,
Balloo
I had to have a belt and rear sprocket replaced under warranty on my last bike for exactly this reason.
They love "tar and chips" around here because it's cheaper than paving.
In my case they did the street right in front of my house so I couldn't avoid it.
Fortunately the dealer caught it during a regular service and fixed it for free.
The sprocket had a few gouges in it and the belt was starting to look chewed up due to some lodged gravel...
At the time they even mentioned that it was a good thing I hadn't removed my belt guard, as many do, since that would have voided the free replacements.
Old Jul 12, 2017 | 04:01 AM
darkcustom7's Avatar
darkcustom7
They do this all over my area, here in PA. I try to avoid at all cost.
Old Jul 12, 2017 | 07:08 AM
mskirwin's Avatar
mskirwin
Ran into it last year. Was still hot had no choice but to go through it. Fortunately no damage. Flagman was pissed because I went through it very slow (duck walk).
PA sucks for the way they do repairs.imo
sbergerson
Jul 18, 2013 10:50 AM
Boomer1143
Jul 9, 2013 03:37 PM
wiktor
Jul 2, 2012 06:55 PM
Sammydogs64
May 10, 2011 05:25 AM
PenguinFLHTC
Mar 31, 2010 03:14 PM
