breakout wont start
Old Oct 14, 2017 | 05:17 PM
j_bee's Avatar
j_bee
As a first thing to do, get the battery load tested properly. That's always a first port of call particularly if it has gone flat. It may well be that a bad battery isn't the issue you currently have but regardless have it tested.
Did it go flat through not using the bike or overnight?
It will certainly be worth using speedo diagnostics to check for any current trouble codes. A search on the forum should explain how.
You only have three conventional fuses which it sounds like you've checked and are unlikely with the problem you've described as causing the issue, and there are no relays to check.
Check that the other buttons on the right switch pack are working, the hazards button and front brake switch. This could highlight a connection problem to the switch pack if nothing works. However if either the hazards or brake switch work then that is unlikely as they also need canbus communication to operate.
However, if they're not working either, it may be that the small block connector for that switch gear module isn't connected correctly.
So check for codes first as this should show if there is a communication problem on the canbus to the right switch pack module or a possible problem with the body control module.
Old Oct 14, 2017 | 08:03 PM
badcooky's Avatar
badcooky
Originally Posted by Quark1968
Meter reading 12.85....Tried putting in pni code found right indicator switch not working or right indicator light so now assume start button not working?Any more fuses anywhere?...cheers
Ok at 12.85 is a good reading but it doesn't mean the battery is good but at those numbers the battery should turn over the bike even if it's once or twice or continuous ,so yea it's probably in your elecrical system somewhere , that's why I wanted you to short the solenoid if you can on that model or run power straight to the starter.
Have you done the unplug/plug of electrical connections or the plug and jiggle of connectors and wires whilst starter engaged, some ECU's if you take them out of the circuit they need some reset time so yea , disconnect battery wait 20 mins then reconnect .
Right indicator bulb is good ?
Relays ? Earths?
JBee's post has real merit follow that line of reasoning to a conclusiuon.
Yea the can/bus deal .
The more you know "what it isn't " the less it can be.
Old Jul 4, 2019 | 11:03 AM
Brent Tite's Avatar
Brent Tite
Stage III
Default Same issues
Relays ? Earths?
I am having the same exact issue with my 2014 Breakout still haven't found out what it is I would like to keep up with this in case you solve this issue mine did not have this problem until I got in an accident so I actually took my to the dealer to get an estimate on fixing just to see if maybe they could come up with a solution 2 why the engine will not even crank over or Pump Fuel
Old Oct 16, 2021 | 04:57 PM
Dutchcoby12@gmail.com's Avatar
Stage I
Default 15 breakout
Hello everyone 15 breakout. Doing same thing. Power everywhere excet. No right turn sig, no flashers, starter no 3ngage. About to ck can bus.
Connor2012
Electrical/Lighting/Alarm
Apr 28, 2017 08:47 PM
nighty0619
Apr 6, 2014 12:25 PM
DGDyna
May 18, 2013 11:31 AM
HarleyMerta
Jul 21, 2010 04:44 PM
masterblaster
Jan 14, 2008 11:28 AM
