Shift Lever Spacer Question
Old Oct 26, 2017 | 04:44 PM
Coffee47's Avatar
Coffee47
6th Gear
Default Shift Lever Spacer Question
OK here is my dilemma this first bike so knowledge of things is old like 20yrs ago and dirt bikes of my buddy's anyway I have but on a Kuryakynk spacer for my shift lever as I have big feet and the heel and toe shifter was causing me up shift when I did not want to....basically stall trust me it took me a few time to figure it out WTF hence the spacer, so back to my question the assembly comes with a rather thick plastic washer with a rubber O- ring going to the inside of the housing bracket to the linkage. I assume this is to keep out dust and moisture and help keep the assembly lubricated. I have had to remove said plastic washer and but the metal or aluminum side to the O-ring so the shifter fit on correctly is this what other have had to do or is there another way?? Sorry just realized 2012 heritage classic that info might help a tad...
Old Oct 26, 2017 | 06:33 PM
dfwhockey17's Avatar
dfwhockey17
Is this what you have? https://www.kuryakyn.com/products/71...ver-eliminator
Instructions: https://maggroup.blob.core.windows.n...-22HD-0207.pdf
Get one of these too: https://www.kuryakyn.com/products/70...er-shift-lever
Pictures would help a lot...I wear a size 13 shoe and while I LOVE and use my heel shifter, the stock shift lever was too short, especially with my extended floorboards. Now my foot fits flat on the board between the shifters and shifting is much easier.
jacknthebox
Aug 24, 2013 05:28 PM
DaSham58
Dec 19, 2008 01:34 PM
PDDGM
Oct 9, 2008 04:42 PM
Cue
Jul 18, 2008 11:36 AM
wireman2511
Mar 14, 2006 03:48 AM
