Handlebar Wire and Cable Extension
Old Apr 10, 2018 | 05:05 AM
Reaper21's Avatar
Reaper21
Default Handlebar Wire and Cable Extension
So I have called around and keep getting different answers. Has anyone raised their handlebars and kept the stock wires and cables? How high can I go?
Old Apr 14, 2018 | 12:19 PM
Toolmaster's Avatar
Toolmaster
That depends on the motorcycle you are working on, My 2018 heritage might be able to go 1"
Old Apr 15, 2018 | 08:15 AM
DrPlastic's Avatar
DrPlastic
When I swapped out the drag bars on my 2016 Breakout with a set of 2017 Fatboy-S bars there was plenty of length in the wiring (as the excess is folded up alongside the frame rails under the tank). As was the clutch cable. Now the upper brake line was a different story. I had to put on a longer (35") one. Interestingly enough there is still a few inches of cabling under the tank for taller bars/risers if I need it later on.
Kingwilliamxxvi
Jul 8, 2019 02:58 PM
Burbur2
Feb 8, 2019 08:49 AM
Jimmy Dixon
Oct 31, 2018 07:01 AM
sledhead140
Nov 3, 2008 09:21 AM
dynamac
Aug 2, 2005 01:38 AM
