Red key light
Old May 30, 2018 | 11:40 AM
victamized62517's Avatar
victamized62517
2nd Gear
Default Red key light
2012 Street Glide just installed custom dynamic turn signals front and rear (led) now when i put turn signal on the red key light comes on?
Old May 30, 2018 | 11:54 AM
Prot's Avatar
Prot
What is a red key light?
Street Glide is a touring bike, not a Softail by the way.
Old May 30, 2018 | 11:55 AM
victamized62517
2nd Gear
Who said it was a softtail?
Old May 30, 2018 | 11:59 AM
nevil's Avatar
nevil
You posted in the Softail section, ergo the comment.
As for your problem, you might need to install a load equalizer after putting on LEDs.
Old May 30, 2018 | 12:05 PM
victamized62517
2nd Gear
Didn"t realize i did that,my bad!
Old May 30, 2018 | 12:12 PM
Mike Lawless's Avatar
Mike Lawless
When I put the signal flasher for LEDs, (the one that modulates the brake light to flash rapidly for added visibility) it said right in the instructions that it may trigger the security light (red key), and that it is normal. I reckon they couldn't program it out, so they just called it normal. Since the stock signal switch is within the security control box, I reckon there's no way around it.
Been going like that a couple years now. No other issues
Old May 30, 2018 | 12:22 PM
victamized62517
2nd Gear
Ok thanks
victamized62517
May 30, 2018 12:07 PM
Jake3kidz
Screamin Eagle CVO Models
Jul 4, 2017 09:24 PM
ajnigli
Jun 5, 2017 05:13 PM
wjfisk
Feb 27, 2014 06:21 AM
JVDeuce
Jun 5, 2012 09:43 PM
