1988 Gas tank schooling please
Old Mar 28, 2019 | 09:04 AM
Rijan's Avatar
Rijan
Default 1988 Gas tank schooling please
Hi Guys,
Ok I have a 88 FLSTC I have the 2 tank set up. I understand that I have the cross over tube going from the Right tank to the left. When I bought the bike the side with the ON,OFF RES tank is full the other side (right)
Does not have much gas in it. Am i missing something is one a reserve does the right side of the tank empty first and the left side that is full is the reserve. Hence I need to fill the right side . Im a little confused .
Old Mar 28, 2019 | 09:47 AM
hdbob2006's Avatar
hdbob2006
Dual tanks with a crossover acts as a single tank.It has more gas in the left tank because it's been leaning over on the kickstand. The on/reserve/off is a function of the petcock. 'On' is running gas through a taller tube than 'reserve'.
Old Mar 29, 2019 | 06:23 PM
Uncle G.'s Avatar
Uncle G.
Even though the tanks are connected, you still have to fill both tanks. If you fill only one tank, it takes so long for the level in both tanks to equalize through the tiny quarter-inch crossover line that you won't get both tanks full if you fill only one.
The way I do it is to fill the right tank first right to the top, cap it off then remove the left cap and fill the left tank to an inch below the neck. That was the way an old-timer told me to fill that tanks and it's worked for me for 25 years.
Old Mar 29, 2019 | 06:42 PM
TSheff's Avatar
TSheff
Exactly. The crossover will equalize very slowly, If you only fill one side, don't expect to ride a long ways before the next stop.
Old Apr 1, 2019 | 05:03 AM
RANGER73's Avatar
RANGER73
When you fill up you fill both sides, left side first then the right side while watching the left so it doesn't overflow
Being the 2 tanks are connected the gas will seek to be level,so the left will have more gas when on the jiffy stand.
There's also a crossover tube on top for air displacement.
The left side (the side with the petcock) has a non vented gas cap, only the right side cap is vented.
This is so when the bike's parked if the fuel expands from being over a hot engine or parked in the sun it doesn't overflow.
Old Apr 1, 2019 | 09:27 AM
Rijan's Avatar
Rijan
Thanks Ranger73
How can I tell if the right side cap is vented looks like previous owner either placed a chrome decorative caps on both or it came this way.
Thanks
Reg
Old Apr 1, 2019 | 10:55 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I always put the left side cap on as soon as it is full, no chance of overflow, unless I slop fuel all over the right side tank, but that has never happened, really, honest, I wouldn`t lie.....
Old Apr 1, 2019 | 11:42 AM
Rijan's Avatar
Rijan
HUM...Ya never had that happen
Old Apr 1, 2019 | 06:29 PM
RANGER73's Avatar
RANGER73
Originally Posted by Rijan
Thanks Ranger73
Thanks
Reg
If you've been riding the bike and it hasn't stalled it's vented somewhere.
If it weren't it would get vacuum bound and gas would stop flowing.
ersee36
18
May 1, 2024 06:01 PM
sammer4u
May 5, 2016 08:03 AM
89FLHTC
EVO
43
Mar 7, 2016 07:21 PM
creed0423
Sep 9, 2012 02:11 PM
99FXST
Exhaust System Topics
Feb 8, 2006 03:35 PM
