Electrical issue! Speedo, other things stopped working
Old Jun 27, 2019 | 05:26 PM
tryoung71's Avatar
tryoung71
Default Electrical issue! Speedo, other things stopped working
2014 Fat Boy
On a ride the other day, all of the following things quit working all at once:
Speedometer
Auto-cancel feature for the turn signals
6th gear indicator lamp
Gear indicator on the GEAR/RPM feature in the digital tach readout
To top it off, the idle is rough when stopped and the bike will stall if I don't keep some twist in the throttle. If I let the bike die and start it up again, the idle issue is fixed, but the list above still not working and if I ride any distance, the idle issue returns.
I have checked my fuses and all 3 are good.
Anyone have any ideas where I might look to solve the issue? Bike is well-maintained by me but I don't know a damned thing about electric issues.
Old Jun 27, 2019 | 06:44 PM
Spindrifter's Avatar
Spindrifter
My first guess would be voltage regulator
Old Jun 28, 2019 | 11:29 AM
tryoung71's Avatar
tryoung71
Okay, so since I know next to nothing about electrical stuff (learning as I go and thankful for people who have experience who can help point me in the right direction), I'll tell you what I did:
I hooked up my multimeter to my battery and with the ignition off I was reading 12.31 volts. I started the bike and the voltage went up to 13.66.
Does that tell me that the voltage regulator is working properly? I would assume that, if the voltage dropped when I fired the bike up, that there is an issue with the voltage regulator. Is there something else that I should do to test the voltage regulator? Sorry if these are novice questions, but I appreciate you taking the time to answer.
Old Jun 28, 2019 | 12:27 PM
Bone Doc's Avatar
Bone Doc
Speedometer
The problem is your vehicle speed sensor (VSS). Try cleaning it. It that fails, then replace it. Both are simple jobs and inexpensive, too.
Old Jun 28, 2019 | 01:11 PM
mmesa005's Avatar
mmesa005
https://www.hdforums.com/how-tos/a/h...-sensor-412957
Old Jun 28, 2019 | 03:59 PM
tryoung71's Avatar
tryoung71
I appreciate that, Bone Doc. I just looked up the VSS on the forums, and it sure seems as if that is the culprit. I will be checking that out immediately. Thanks again!
Old Jun 28, 2019 | 04:49 PM
Shellfish20's Avatar
Shellfish20
Default Vehicle Speed Sensor for sure
I had exactly the same symptoms and the VSS was the culprit.
I ended up replacing as a clean made no difference.
Here's a tip though, a skinny set of hands will help no end, otherwise get a friend to help. Allen keys are almost the only tool needed (3/16?), its tucked away under a plastic electrical panel just in front of the rear wheel
Steve
Old Jun 28, 2019 | 06:07 PM
tryoung71's Avatar
tryoung71
Steve
I appreciate that, Steve. I just came in from looking my bike all over and couldn't find the VSS. I found what I THOUGHT was it, but after removing it, realized it was not. Cheers!
Old Jun 29, 2019 | 12:47 PM
Pitbull_Dallas's Avatar
Pitbull_Dallas
Hmmm, now I'm kinda wondering if the speed sensor might be responsible for the problem I ran into a couple of days ago.
https://www.hdforums.com/forum/softa...m-for-you.html
Edit: Tryoing71, here's a video that may help you..
Old Jun 30, 2019 | 10:11 AM
tryoung71's Avatar
tryoung71
https://m.youtube.com/watch?v=0ByQwuXGT4o
Yep, that's the video I was watching, too. I got all the way to removing the 3 bolts on the plastic bracket but no matter what I tried, I could NOT get that damn thing out of the way so that I could get to the VSS. I hate to take the bike to a shop, but I don't really have the time to take the rear wheel off to get easier access to the VSS.
