2008 rocker security system issue
Old Nov 8, 2019 | 05:03 PM
Joeshaby's Avatar
Joeshaby
Stage III
Default 2008 rocker security system issue
Hi all, I tried searching everywhere for a similar issue with no luck so hopefully someone her might have a clue on what could be the issue
I was starting my bike turned the key on and suddenly the siren beeped once and that was it, the bike won’t start. Turned the key off then on but this time the dashboard lights are off and only the red security light lamp is on, turn signals not working and the bike won’t start
when key off the double beep and signals flash don’t happen and the red security lamp is not blinking.
i checked all fuses, the battery is new and working fine and just replaced the fob battery
so anyone have an idea on what might be the issue here?
thanks
Old Nov 10, 2019 | 03:35 PM
duluth's Avatar
duluth
Just a guess, could the ignition switch have gone bad? When you turn the key does it feel like it is rotating to the start position?
Old Nov 10, 2019 | 05:34 PM
Joeshaby's Avatar
Joeshaby
Stage III
it’s working fine, when I turn the key head light, oil lamp and gear indicator all light up and putting the ignition switch to on I do hear the fuel pump starting. It’s just the gauge is out and only thing lit in it is that annoying red dot 🔴
Old Nov 11, 2019 | 06:43 PM
1004ron's Avatar
1004ron
Try the overrride PIN number and see it starts.
Old Nov 11, 2019 | 11:21 PM
Joeshaby's Avatar
Joeshaby
Stage III
how can I do that?
Old Nov 12, 2019 | 05:53 PM
1004ron's Avatar
1004ron
Originally Posted by Joeshaby
how can I do that?
If the using the instructions below doesn't reveal your PIN, maybe because the FOB is bad, you can do the 30 minute password re-learn procedure, which will allow the bike to start, but only a dealership can re-marry the FOB's to the bike.
https://www.cyclefish.com/blogs/72/4...m-pin-override
https://www.hdforums.com/forum/elect...roceedure.html
Ickysticky74
May 10, 2023 09:21 AM
AA79912
Feb 13, 2013 08:42 AM
YoDA
Dec 18, 2010 06:17 PM
CCNitro
Mar 28, 2010 03:20 PM
Mikey_HD
Oct 18, 2006 11:00 AM
