I need some advice.
Old Nov 30, 2019 | 12:12 AM
2000hdd's Avatar
2000hdd
Stage I
Default I need some advice.
I have a 2000 carbureted softail Deuce. While riding the engine light comes on and off the speedometer dies and or the odometer goes out and comes back on. The bike runs fine through all of this. What’s wrong with it?
Old Nov 30, 2019 | 07:29 AM
MyFavRk's Avatar
MyFavRk
First I would check for codes and see what is registered , should help pinpoint the area you need to concentrate on . Have a look at the wiring / connections at the speed sensor , could be broken or corroded . Removing the speed sensor , mounted on top of the tranny , wipe it clean and see if that helps .
Hope this helps , good luck
https://www.hdforums.com/how-tos/a/h...e-codes-413169
Mikemetal
Exhaust System Topics
Aug 12, 2019 11:37 PM
07JakeelwoodHD
Sep 27, 2013 07:58 AM
smbwn
Apr 28, 2013 08:06 PM
willie380
14
May 23, 2012 08:08 PM
ijminerva
Oct 21, 2010 09:24 PM
