high volume oil pump
Old Feb 2, 2020 | 01:05 PM
Etooch's Avatar
Etooch
Stage II
Default high volume oil pump
Hi All,
Workig on doing cams, hybrid cam plate and high volume oil pump. I have a question on the oil pump assembly. The original pump had a groove for an oring. The new pump has no groove for an oring, pump is larger than stock. Just checking if an oring or gasket is evn needed to join the pump to the screaming eagle cam plate. Thanks in advance
Old Feb 3, 2020 | 06:53 AM
ghost183's Avatar
ghost183
which pump are you installing brother? that would help greatly
fyi..
my fueling 7060+ had an O ring between pump to cam plate.. which it too was larger than my SE oil pump
Old Feb 3, 2020 | 07:03 AM
Etooch's Avatar
Etooch
Stage II
25284-11 screaming eagle cam chain tensior plate upgrade kit with high volume oil pump
Old Feb 4, 2020 | 11:12 AM
hattitude's Avatar
hattitude
I have never seen in person, or installed the Screamin' Eagle kit #25284-11...... BUT ....
Looking at the install instructions, namely figure 8 and table 2, they don't show nor do they list an o-ring between the oil pump and cam plate... So I suspect there is not supposed to be one...
https://serviceinfo.harley-davidson....3?locale=en_US
And even though they are not part of the kit, DO NOT forget the 3 o-rings (#11x2 and #9) in this diagram.... they are important!!
If your old ones are in any way suspect, get new ones....
Gtop
Milwaukee Eight (M8)
Oct 31, 2018 03:38 PM
jaxdwg
Feb 28, 2016 11:14 AM
navcan
Apr 8, 2015 12:36 PM
BuzzL
Jul 4, 2013 01:35 PM
mbierbac
Exhaust System Topics
Jan 19, 2012 06:11 PM
