Red Key light indicator on...and i did search around
Old Aug 27, 2020 | 07:48 PM
champ198's Avatar
champ198
Default Red Key light indicator on...and i did search around
so saw yesterday that I had the red key light indicator on. so got on here and did some searching and found how to Diag it.
this light came on after putting Red LED bulbs on the bike. so after some looking I figured out it is the red bulbs I bought for the rear turn signals.
reason for the question is I do have the Custom Dynamics Smart triple play module on the bike so I can get some strobe on the rear lights to be able to be seen better.
my question is do I need their Load Equalizer to get rid of the red key light and keep the red bulbs? new with some of this stuff and not sure how to go about this.
the only time the red key comes on is when the turn signals are used.
if I put the old incandescent bulbs back in it does not throw a code.
Bike is a 2007 Heritage and does not have a FOB
Old Aug 27, 2020 | 07:51 PM
kel03's Avatar
kel03
Have you called Custom Dynamics yet? I have heard they are pretty good, have their tail light. I have also heard that you run thru your light switches ie turn signals on, emergency flashers, etc so the ECM learns they are there.
Old Aug 27, 2020 | 08:00 PM
champ198's Avatar
champ198
I haven't called them yet just due to my work Schedule starting today.
Old Aug 27, 2020 | 08:19 PM
kel03's Avatar
kel03
Run thru the switches then, that's an easy one.
Old Aug 28, 2020 | 12:59 AM
ChiFLSTN's Avatar
ChiFLSTN
Do you have LEDs in your front turn signals as well? I've got a 2007 Deluxe and when I put Custom Dynamics LEDs in the rear bullets along with the smart triple play, like what you're describing, everything worked fine. But once I put Custom Dynamics LEDs in the front signals as well, I started getting the hyper flashing/odd behavior other people have complained about. Finally figured out is seems you can have LED in the front OR rear without a load equalizer, but not both. Once you do LED front and back you will need the equalizer, at least on the 2007 Deluxe. I added the CD equalizer and everything's working fine now.
Old Aug 28, 2020 | 12:04 PM
Mike Lawless's Avatar
Mike Lawless
I have the red key light too in my '06 Deluxe. LED bulbs and Kuryakin load equalizer/brake light flasher gizmo. It says in the documentation that this will happen and there's no work-around. This is a 4 year old device. Don't know if things have changed, but the red key light has caused no issues that I can tell. I know what it is, so it doesn't bother me
Old Aug 28, 2020 | 02:54 PM
Custom Dynamics's Avatar
Custom Dynamics
Former Sponsor
On a 2007 Heritage, you will need a load equalizer/Smart Signal Stabilizer in order to run the Triple Play and not get that red key light coming on. Later Softails with CanBus electrical systems (2011 and newer) don't need the Signal Stabilizer to run our LEDs.
Basically, your flasher can tell how much electricity is being used on the turn signal circuit. The Triple Play itself does remove load from the turn signal circuits. Plus, you have LED bulbs, which also draw less power than the stock incandescent bulbs.
If you have our green Triple Play module (GEN-SMART-TPU-HD), then you need the blue Signal Stabilizer (GEN2-SSHD).
https://www.customdynamics.com/stand...arley-davidson
We also make these two units combined into one box now. That part is the CD-TPU-SS-HD.
https://www.customdynamics.com/load-...arley-davidson
Old Aug 28, 2020 | 09:39 PM
klf33's Avatar
klf33
Normal behavior, either buy a 'load equalizer' or just stop looking at it (what I do ).
This used to happen only on models with security alarm system.
victamized62517
May 30, 2018 12:22 PM
victamized62517
May 30, 2018 12:07 PM
Jake3kidz
Screamin Eagle CVO Models
Jul 4, 2017 09:24 PM
ajnigli
Jun 5, 2017 05:13 PM
jooman07
Electrical/Lighting/Alarm
Jun 17, 2014 09:27 AM
