Softail wiring questions
Old Feb 13, 2021 | 05:42 PM
nadajoey's Avatar
nadajoey
Default Softail wiring questions-Can someone tell me what this wire is?
Hello. My 04 FXSTS has an aftermarket tank and original owner disconnect Speedo and indicator lights. I’ve found both wiring harness under the tank...good thing so I can connect an aftermarket Speedo, however in looking at the wiring I found a wire with what appears to be a sensor at the tip.
can anyone confirm what this. Part of the wiring is connected further down but this wire is not.
here is the pic
Mysterious wire
Old Feb 13, 2021 | 08:29 PM
back again's Avatar
back again
The only yellow white stripe wire on the bike is the fuel tank float level. That looks like a spur off the sending harness. There are 3 wires for tank float. Orange,black and yellow white stripe if I remember. Does your gauge work?
Old Feb 13, 2021 | 08:42 PM
nadajoey's Avatar
nadajoey
thanks for confirming! no, actually, it is not functional, the former owner removed the tank and never replaced the fuel gauge.
i also have another strand of wires which i believe is the speedo or indicator lights. (i gotta get a bike manual so i can read the wiring diagrams)
thanks again!
Old Feb 14, 2021 | 10:35 AM
nadajoey's Avatar
nadajoey
Purchased my Softail manual and from the likes of the wiring drawing this would appear to be my Speedo harness (7-8 wires inside the sleeve) Can someone confirm as some of the Colors don’t match my drawing (might be covered in dirt)
appreciate the help! Looking forward to installing back an aftermarket Speedo !
Wiring harness underneath the tank. (No connector)
shewey
Mar 30, 2024 08:27 PM
Zephyr550
Electrical/Lighting/Alarm
Mar 15, 2019 09:16 AM
digvid
Feb 17, 2018 10:48 PM
ballbreaker69
May 16, 2015 08:14 AM
ReidRik_Von
May 25, 2014 05:08 PM
