Softail custom or duce
Old Oct 28, 2021 | 05:19 PM
slickman's Avatar
slickman
Default Softail custom or duce
I’m looking at two bikes, softail custom or softail Duce. Which will handle better at low speeds. I’m torn which one to get.
Old Oct 28, 2021 | 06:03 PM
SPRINGER's Avatar
SPRINGER
Not everybody handles a bike in the same way. Based on that, do you have the opportunity to test ride each bike and maybe answer your own questions?
Old Oct 28, 2021 | 07:07 PM
Paintslinger16's Avatar
Paintslinger16
Active Streak: 120 Days
It’s basically the same bike, same frame and suspension, softail, could be a slight degree difference in rake but they should handle pretty near the same. Go with the best deal or the one that you like best, a Softail is just not known for super handling.
quick edit, so coming off a sporty which is a little top heavy feeling, you will sit in any softail a little better
Old Oct 28, 2021 | 07:11 PM
slickman's Avatar
slickman
Is the handling due to the rear softail design over say a super glide?
Old Oct 28, 2021 | 07:14 PM
Cap77's Avatar
Cap77
never rode a STC
but looking at specs, rake is same and the rest (wheelbase, trail, etc) is virtually same, as Paintslinger mentioned
STC is 20 pounds heavier and seat is an inch or two lower
..L.T.A.
Old Oct 28, 2021 | 07:17 PM
Paintslinger16
yes, a Dyna will handle better and easier to make it even better if you wanted to go that route.
softails look great because of the lack of the outside shock, but they have very limited travel nothing is easily adjustable.
if you really want a bike that many consider to be the best factory, look for a FXR
Old Oct 29, 2021 | 06:15 AM
shovel52's Avatar
shovel52
I would say that the Softail custom will handle better at slow speeds than the Deuce. The smaller handlebars make the Deuce feel somewhat top heavy at slow speeds. I really prefer the Deuce simply because I like the overall custom feel of it. Sometimes I feel like I am manhandling the Deuce. It is all a matter of preference and ability and upper body strength. The forward controls on the Deuce are pretty comfy at speed. I have owned both and keep drifting back to a Deuce for my run-around machine. Ken
Old Oct 29, 2021 | 07:10 AM
eighteight's Avatar
eighteight
ST handling also limited by lack of lean angle
Old Oct 29, 2021 | 07:55 AM
uncle kebo's Avatar
uncle kebo
Ive owned a STC. Its not a canyon carver but it is stable and easy to ride. Traffic at 4 mph, theres not a single bike in the world thats an easy ride just some easier than others.
Old Oct 29, 2021 | 08:37 AM
JohnnyMagic's Avatar
JohnnyMagic
Not the same but opinions differ.
The Deuce was reviewed and reported to be one of HD's best handling bikes at the time.
I bought one new (2000) and found it to handle way better than my 85' Softail and even slightly better than
my 88' FXRS (yes better than the FXR!)
Ran a 200 rear and 130 (21) front and I can really lay that bike down in turns.
Like anything newer, my 2020 FXDRS is on another level . Even with the 240 rear?
JM
