About a year ago I replaced my compensator with the Man-O-War 32 tooth sprocket, from Pro Twin. It came with a thick shoe to add to the stock auto adjust tensioner.
During the install I discovered the auto tensioner had tensioned the chain too tight, causing the symptoms that made me suspect the comp.
I am about to pull the primary cover to inspect for wear and tension. If find the auto tensioner has overtightened again I will replace it with a manual tensioner.
I know the Baker is good but pricey at about $280. I would like suggestions on an alternative that will work with the 32 tooth sprocket to take up the extra slack but a little less pricey for a tensioner.
What are my options?
Boys, those Hayden units everybody is so in love allow that chain the jump like crazy at speed. It does not keep the chain at a steady consistent level like a manual adjust will. Did a test on a kick start bike with one of those with all the shim plates installed. fired the bike up and used a timing light to watch the chain at varying speeds. As it spins the RPM's up the spring compresses and bounces allowing the upper part of the chain warp in a S wave shape that almost hits the screw bosses on the older inner covers.
Notice later model bikes with the auto adjusters have the bolt bosses on the outside now ? Think about that.
Is no magic free lunch when it comes to primary chain adjusters, you want it right you do manually and have open and correct things as part of the regular maintenance regiment.
That is another automatic tensioner and don't believe it will work with the 32 tooth sprocket.
Thanks for the input.
It's spring loaded and the number of teeth on the sprocket doesn't matter,
but TwiZted has a valid point.
The auto tensioner can fool you. With outer cover off, the first end of slack you see when you push up on chain is the free slack. However, when you push up harder, you are collapsing the two small coil springs in the tensioner. That also is considered free play.
It can fool you and has many many people. If it is indeed too tight (less then 1/2 total when pushing firmly) your chain has uneven wear and is letting tensioner pull up in the worn areas and then too tight in non worn areas.
Chains get this way from engine breaking downshifting rather then using brakes and hot rodding.
Your sprockets may also be running out. I have been able to get slack closer to be the same thru the whole chain length by indexing the sprockets and front compensator adapter spline.
Check tension ever 5" on so on chain.
I believe the tooth count does matter. The 32 tooth sprocket causes much more slack in the chain and the Hayden adjuster is not designed to set proper tension with that much slack. Also as TwiZted said, I think I want the manual adjuster.
Thanks for the input Ripsaw. I plan to check the runout when I pull the cover I will pull the sprocket and clutch again to use a dial gauge on shaft.
How do I tell if the chain is stretched or worn?
