07 springer: front brake weak
Old Aug 10, 2007 | 10:04 PM
bigdeek's Avatar
bigdeek
Default 07 springer: front brake weak
Howdy all.
Have all of 33 miles on my new 07 springer. The front brake is weak, at best. Is this because of the springer front end not being able to handle too much torque from the caliper assembly, so they left the single piston assembly on there or what?
I noticed the rest of the softails have 4 piston calipers up front, but we got stuck with a measley single.
edit: for those who don't browse the Touring Models forum here, at least check out this awesome post: https://www.hdforums.com/m_2036304/tm.htm
Old Aug 10, 2007 | 11:36 PM
detonator's Avatar
detonator
Default RE: 07 springer: front brake weak
Ya its a freakin joke.
Old Aug 11, 2007 | 02:11 AM
Tralfaz's Avatar
Tralfaz
I've got 310 miles on my Springer now and am getting pretty used to the brakes. I was a bit concerned at first, but compared to my Sportster with a single piston rear brake and 2 piston front, versus the Springer at least having a 4 piston rear brake, I feel like my stopping power on the Springer is a little bit better. I have not tried any quick stopping yet since I'm still in the break-in period, but it's still better than I expected.
That being said, though, when just using the front brake on a slow approach to a stop, I definately have to be more careful about my distance with the Springer over the Sportster.
Old Aug 11, 2007 | 04:46 PM
F117ewo's Avatar
F117ewo
After having a single front disk and a rear drum on my last bike, my 06 FX Spinger stops just fine. I haven't done it for an emergency, but the stopping power is there. No, it's not the nosebleed braking you get with twin disks up front, but it is strong when needed. It will lock up the front tire if you get into it real hard. That's all that's needed.
Jake
Old Aug 11, 2007 | 11:53 PM
SKT's Avatar
SKT
I felt a big difference compared to my Dyna that has dual discs up front.
Shortly after taking delivery of my '07 Springer Classic, I was not happy at all w/ them.
Tried to re-bleed them to no avail.
Swapped out to steel braided lines and felt a little better.
Although still not a perfect solution, I have come to accept it, and brake accordingly now...
Old Aug 12, 2007 | 12:16 AM
Tralfaz's Avatar
Tralfaz
ORIGINAL: SKT
I had read some things on the forums about switching to steel braided lines helping. So it does feel like it helped out with the braking power for you? It does make sense that a more rigid line should help a little. Does it feel like the upgrade was worth it for the braking power you got out of it?
Old Aug 12, 2007 | 12:55 AM
detonator's Avatar
detonator
as with any brake line steel braided is going to be better do to less expantion, were in a rubber line expands more making brakes feel spungy! I feel it would be a good upgrade do to quicker brakeresponse with steelbraided it wont make a world of difference but it will help.
Old Aug 12, 2007 | 07:23 AM
SKT's Avatar
SKT
ORIGINAL: detonator
Exactly what he said...
SpyGoat
Jul 5, 2017 10:23 PM
NoRegerts
May 9, 2011 02:33 PM
Huey Driver
Dec 19, 2007 02:10 PM
Tralfaz
Jul 20, 2007 11:32 PM
msheldon
Nov 20, 2006 12:54 PM
