Idle Adjustment
Old Feb 15, 2022 | 03:41 PM
vtbigdog's Avatar
vtbigdog
Originally Posted by JLC2012FATBOYLO
Ok. I will look at the clutch adjustment. Thanks
If you are going to have the derby cover off I would also check the fluid level to make sure there is not too much oil in the primary case. There are several threads in here which discuss how much oil should be in the primary. For example my fat boy says to put 1 qt in when changing the fluid. However a quart of oil makes the level too high which causes the clutch to slip as well as the clunking sound that you mention. It also causes the release point in the clutch handle to be almost to the point where clutch handle is almost completely released. I would say if these 3 symptoms are happening in your case, the clutch is out of adjustment as there is too much fluid in the primary.
Old Feb 15, 2022 | 04:36 PM
RANGER73's Avatar
RANGER73
Originally Posted by LenBoyLo
B&M trick shift works for me as well.
80259 or 80262?
Old Feb 15, 2022 | 05:43 PM
brakeless's Avatar
brakeless
Originally Posted by RANGER73
80259 or 80262?
80259 is what I use. The 80262 is synthetic and the clutch mfgr says not to use the slippery stuff.
Old Feb 15, 2022 | 06:26 PM
RANGER73's Avatar
RANGER73
Thanks, just ordered a QT.
Stuffs hard to find at a reasonable price. No one around me has it.
Old Feb 15, 2022 | 06:34 PM
brakeless's Avatar
brakeless
My local Napa Auto Parts carries it. Can't remember exactly what I paid but I think it was only about $10.
Dazzauk
EVO
21
Sep 6, 2016 12:01 AM
ultraclassic53
May 7, 2015 07:52 PM
AAAC
EVO
Apr 21, 2014 08:58 PM
Silvertrain1025
Mar 2, 2013 09:31 AM
Willy G.
Apr 8, 2009 07:02 AM
