Harley startup after sitting for over a year
Old Jan 20, 2023 | 10:16 PM
Harleydude57's Avatar
Harleydude57
1st Gear
Default Harley startup after sitting for over a year
I have a 1999 Heritage Softail Classic which hasn’t been started in over a year. Need some advice on what to do before attempting to try to restart. Bike has been garage kept and on my bike stand. Open for for any help. Thanks
Old Jan 20, 2023 | 10:23 PM
LightninST's Avatar
LightninST
Definitely fresh fuel ⛽️! Did you leave fuel in the tank or was it empty.
Old Jan 21, 2023 | 05:21 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
If you added a fuel stabilizer to the gas tank then just put it on the floor, insert the key, and fire it up! If you put non-ethanol gas in the tank then put it on the floor, insert the key, and fire it up. Not rocket surgery!
Old Jan 21, 2023 | 05:26 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Be ready for oil to puke out the breather.
Old Jan 21, 2023 | 07:40 AM
Cap77's Avatar
Cap77
Charge the battery
..L.T.A.
Old Jan 21, 2023 | 08:26 AM
Tc88b's Avatar
Tc88b
Ok, since you're asking I'll put in my two cents. Fresh gas is good to have but not a necessity. But if the gas tank was not full I would first add some fresh gas before starting. Make sure the battery is in good condition and fully charged. Personally, what I do every spring before starting it (I live in Canada so the bike sits for months) is I pull the plugs and squirt a little bit (half a teaspoon full) of oil into the cylinders then I turn it over with the plugs removed for a good 15-20 seconds. I do this to ensure the cylinders are lubricated and want the oil pump to start circulating oil throughout the engine. Think of a fresh rebuild. Do you just add oil and just start 'er up or do you first prime the oil pump and get the life blood running and pressure built up before start up? Remember, most wear occurs on start up and your bike has had A LOT OF TIME to allow the oil to drain from those cylinders. Oil is in the engine to prevent metal to metal contact so make sure it has a chance to do that. Now, put the plugs back in (good opportunity to check the condition of the plugs and gapping) and fire it up. Let the bike idle for about a minute and listen for any unusual noises. Do a quick walk around and check lights and brakes either before you start it or while waiting for it to warm up. Now go for a ride. Make sure the ride is long enough to bring the engine up to standard operating temperature to burn off any excess moisture and make all the parts happy to know each other again. Dump the old oil and put in some fresh stuff upon your return since it sat for a year (I wouldn't do it if the bike sat for a few months over winter unless the oil was nearing it service limit). Show your ride some TLC and it will reward you with a long service life.
Old Jan 21, 2023 | 08:32 AM
ConfuciusSay's Avatar
ConfuciusSay
Check the air pressure in the tires before you ride that bike anywhere. I guarantee you the tires are low.
Old Jan 21, 2023 | 09:39 AM
Harleydude57
1st Gear
Yes tank has fuel in it. I had added Sea Foam fuel additive and battery has been on a battery tender the entire time. I’ll give it a shot. Thanks
Old Jan 21, 2023 | 09:58 AM
OldEnuf2NoBtr
Fire it up!!!
Old Jan 21, 2023 | 10:15 AM
MattLS6's Avatar
MattLS6
That’s not a long time to sit and sounds like you did your due diligence in storing it. Fire it right up.
El Demonio Escondido
Motorcycles For Sale
May 18, 2013 02:07 PM
skam716
Oct 15, 2010 05:03 PM
bennylax3
Jun 7, 2007 11:40 PM
