First 3-hole
So, admiring my work and cleaning things up from the SOB that overtightened the oil filter to holy-hell tight and turned a simple job it a real bitch and a mess - I spot a 1/8"pipe plug in the right side engine case down under the cam cover. There is nothing in the manual about removing that and what I suspect would be to drain the case oil laying there. Does anyone remove that plug to get all the oil you can out for the oil change? Maybe it's a casting plug?
As the manual stated I put just a touch over three quarts in the oil tank and it is just about perfect for the oil level. You know there is still oil in the case and cam chest - Maybe that pipe plug would get that out. Thoughts?
mine is a typical pipe thread plug.
Only got a couple ounces (at most) of oil out of it
So never bothered to pull it again.
..L.T.A.
The basic answer to the highlighted question is no. Do not remove the pipe plug under the cam chest. That pipe plug is a tapered plug. If overtightened you can crack your engine case and you would be in a world of hurt. If you are concerned with getting every ounce of dirty oil out of your engine then use the Rogue Chopper Oil Scavenger System. It works very well.
OP , don't sweat an once or two still there, just do the regular services and you are good to go.
Oils I used. I'm already going to hell if there is such a place - So here goes. Mobil 1 15w/50 for the engine, Castrol GTX 20w/50 for the trans & Prim. M1 102A filter.
There, I did it.
As for the plug in the bottom. Yes, I could see it was a 1/8" tapered pipe plug and in cast aluminum = "I bet bad things have happened there before" Kind of like the plug in the primary case - I have pipe plugs. I see that needed to be modified later. Again the shop gorilla tightened the crap out of it and it goes in past the spec in the manual now to be tight. Mine sits slightly below flush and the spec was something like .016" above flush. For now it's fine, but I may consider modifying that and going to an O-ring fitting someday.
Edited to fix spelling, is there a spell check on here anywhere?
A TCb also has an 1 & 1/2 inches of oil in crank case.
Don't worry about it. That fresh oil service and a filter is all you need.
Now if you are bound and determined and this is not a tin man post for a flush kit, be sure to not overtightenen that tapered pipe plug.
Use a proper pipe thread liquid sealer. Over Tightening it will crack the aluminum . Seen dozens of cases on here.
Just a few weeks back, on one on a Sporty.
