Rear pulley bolts
I am now pulling the primary and doing both the transmission pulley and the rear pulley. Those bolts had been torqued but the bike was never ridden with them. Could I use them? Is the reason they are one time use due to torquing them down or is it because of the lateral force on them when in use?
Also this is why you don't want to reuse the bolts, you may be okay with cleaning out the hub threads and bolt thread, using loctite, but why take the chance. Follow the manual, there is a reason it was written that way.
Chrome bolts may not be the best way to go if they are not the correct hardness.
I have reused gaskets that are supposed to be replaced, without leaks. I have used the same gasket several times in some of these applications. I just inspect them to make sure they aren't damaged by use of removal...
However, I am not a machinist. Nor do I have any metallurgy background or training. I am aware of these two aspects of why a bolt could be "one time use".
There are bolts that are "torque to yield". They are designed to have a final torque spec that actually stretches the bolt. This causes the bolt to lose some of its elasticity. If you reuse one of these bolts, it will be weakened and may not effectively provide the needed clamp load.
There are also bolts that require, and are supplied with a lock patch on the threads. In these cases, I suspect the manual just wants to ensure that you use the proper threadlock on the bolt.
FWIW.... Since I'm not a bolt/metal expert, I tend to err on the side of caution.
If the bolt is a critical fastener, would be either labor intensive to change out, and/or could cause a serious issue if fails to clamp properly (like the sealing screws on the fuel tank plate) I tend to replace them if called for... That's just for my piece of mind.
I have read at length numerous threads about loose drive pulleys... It would appear that most of the problems are due to poor installation or modifications that affect the clamping power of the fasteners, like adding powder coating to the surface where the bolt clamps to, etc.
I have also seen recommendations by people I deem more knowledgeable than me, claiming reuse of the pulley bolts is no big deal, as long as threads are cleaned and red thread locker is applied.
I will say I have reused pulley bolts without an issue, with proper cleaning, thread locker and installation. I would not, however, recommend against the manual on that issue to others, since it is a fastener with a critical job...
Good luck with your repair...
