06 softtail ticking noise
Old Feb 11, 2024 | 10:56 PM
Benji254's Avatar
Benji254
Stage I
Default 06 softtail ticking noise
Hi first time poster, my 06 soft tail stock mods has just clicked over 50,000miles. Have started to notice a ticking noise on idle when hot and de acceleration is where it’s at its worst. Just wondering of any ideas. Of what this could be. I am aware they need there cam chain tensioners done around this time. But been doing it for maybe last 6kmiles? Wanting to sell so want to get it sorted. Cheers
Old Feb 12, 2024 | 04:34 AM
eighteight's Avatar
eighteight
Originally Posted by Benji254
I am aware they need there cam chain tensioners done around this time. . Cheers
Only way to eliminate this possibility is to take it apart and inspect.
Old Feb 14, 2024 | 07:47 PM
back again's Avatar
back again
I’d start with checking exhaust nuts. Easy first check for ticking you’re experiencing.
Old Feb 15, 2024 | 09:46 AM
hattitude's Avatar
hattitude
I'd say you are overdue for checking the spring cam tensioner pads, on both time & mileage. I'd do that sooner than later... regardless of the ticking..
But the ticking, however, as suggested by back again could be a simple exhaust leak... Always check the easy stuff first...
Old Feb 15, 2024 | 12:23 PM
KK0G's Avatar
KK0G
50,000 miles is WAY past when the stock tensioners usually go bad. I'm not saying that's what's causing your noise but regardless the tensioners at least need to be inspected, high probability you'll discover they're worn well beyond spec.
LowBone
Milwaukee Eight (M8)
19
Aug 2, 2021 11:49 PM
outlawspeeder
Exhaust System Topics
Aug 23, 2010 12:31 PM
1peter
Jun 8, 2009 02:30 AM
stglideblk
Oct 26, 2007 11:11 AM
Viejo
Sep 11, 2006 11:08 PM
