Harley Footboards
Old Nov 25, 2005 | 10:27 PM
BobbyT's Avatar
BobbyT
6th Gear
Default Harley Footboards
Anybody know how to take the footboard insert out of the footboard frame without breaking off the little rubber nipples that go through the holes in the footboard frame? I want to get the frames and brackets chromed but can't get the darned inserts out. There must be a trick. Thanks!
03 Heritage Softail
Old Nov 27, 2005 | 02:22 PM
EK5858's Avatar
EK5858
Default RE: Harley Footboards
Use a real slick substance such as a soapy mix and put it all around the nipples. Then use a phillips screw driver and push them up one at a time through the holes. The more slimey the better. Then put them back on the same way. The rubber pull through is gone and you should use some needle nose to pull them back through. Good luck
Old Nov 27, 2005 | 03:50 PM
pococj's Avatar
pococj
I just use a flat blade screwdriver and push them up through. Use the blade on the outside portion of the nipple, not the inside. Usually takes putting the blade in 2 places around the nipple.
Old Nov 28, 2005 | 04:39 PM
05Fatty's Avatar
05Fatty
I would definately use some liquid soap. Then squeeze the nipple together and push it through.
Old Dec 1, 2005 | 03:06 PM
Babs's Avatar
Babs
Yep.. just a lot of liquid soap and some water will do it. Had to pull mine to install cruise arms.. Soap works wonders. Same for putting them back in.
digdug
Mar 22, 2016 09:27 PM
rpmpit
Feb 20, 2013 10:45 AM
Rickr01
Feb 15, 2012 01:57 PM
Chilhowee
Nov 3, 2007 09:02 PM
elkhorn
Sep 28, 2007 09:07 AM
