Battery & Engine Light
Old Sep 24, 2007 | 05:26 PM
tbrashear's Avatar
tbrashear
6th Gear
Default Battery & Engine Light
Hello,
I have a 2006 FLSTNI Softtail Deluxe and I was wondering what it means when the engine light and battery light come on at the same time?
This seems this only occurs when it's hot out and I'm in traffic or on a long ride while it is hot outside.
Any thoughts?
Thanks!
Old Sep 24, 2007 | 05:29 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Default RE: Battery & Engine Light
Wonder if your regulator is cutting out when it gets a bit too hot.
Old Sep 24, 2007 | 10:07 PM
tattoome's Avatar
tattoome
Have you tried running a diagnostice and see what code comes up?
https://www.hdforums.com/m_2158978/m...tm.htm#2158978
Old Sep 25, 2007 | 10:24 AM
safields's Avatar
safields
In my case it turned out to be a bad speedometer unit. The dealer ran diagnostics (allegedly...) three times. Replaced the ECM first, then tried replacing the TSS module, then finally just replaced the speedo with another unit. That seems to have finally cured the problem.
Old Sep 25, 2007 | 01:56 PM
tbrashear's Avatar
tbrashear
6th Gear
I have not ran any diagnostics, but will. Do I have to wait for the symptom to occur before I will get a code? Thanks for all the help!
Old Sep 25, 2007 | 02:10 PM
tattoome's Avatar
tattoome
ORIGINAL: tbrashear
From what I understand from the instructions that I received, the code should show up when you run the diagnostics.
Old Sep 26, 2007 | 09:09 AM
tbrashear's Avatar
tbrashear
6th Gear
Looks like I may have found the problem I ran the diag and it came up wtih the following code...
P0562 Battery Voltage Low EFI
So I am assuming my battery is not holding a good charge. Thanks for the diag instructions and all the help!
Old Sep 26, 2007 | 10:10 AM
tattoome's Avatar
tattoome
Cool, I was getting pretty frustrated with my engine light coming on but after finding help here, I was able to fix the problem and it hasn't happend again. This forum is a great place to find help and get answers.
DaveJFuller
Jul 1, 2014 08:53 AM
StreetGlidinFreak
Jan 12, 2013 06:23 PM
jh.est1975
Feb 29, 2012 09:14 PM
bad news
Aug 14, 2010 01:58 PM
jb bill
Dec 26, 2005 05:28 PM
