the harley stage 1 download does not change the fuel mixture, therefore it's a waste of money, you can buy a pciii used here for the 165 and be able to make the changes as you go for free (or close to it)
Don't mean to be rude, but the HD Stage 1 does in fact change the fuel mixture. It richens it across the RPM band by 5%. The advantage is once it's done it's done. With the PCIII there is a lot of time consuming downloading and fine adjustments to make. And, the best way of getting the PCIII dialed in is to put the bike on a dyno. So, if he picks up a used PCIII for $165.00 and has to have it dyno'd for another $400.00 where is the savings ????The HD Stage 1 is money well spent for a virtually stock bike with a set of pipes and an air cleaner.
