Dry Ice For Dents
Old Nov 6, 2007 | 01:39 AM
drummer3278's Avatar
drummer3278
Default Dry Ice For Dents
I posted this response on my last thread titled "I Think I'm Going To Get Sick" after I dropped a solid wood door down a staircase onto my Scoot's gas tank, but figured I should start another in case someone didn't see it, and might have a dent or two to take out.
"Ok,
After doing some research on our homeowner's policy, it would be best not to go that route. I tried the dry ice thing today, and it actually worked somewhat. It's much better than it was, but still noticeable to me. The problem is that the only place to get dry ice in town sells it in these little bite size pieces instead of a solid hunk. I think if I had a small solid hunk it would make more contact with the actual dent than holding up these little pieces with a glove. I can see that the dry ice thing would probably work great on smaller dents. I'll see if I can find another source for dry ice. I would love to just order a new tank right now, but until our old house sells, finances are as tight as a snare drum. Thanks all for the sympathy and advice!!"
https://www.hdforums.com/m_68440/tm.htm Dry Ice Link. Second Paragraph
Old Nov 6, 2007 | 08:56 AM
wallyn's Avatar
wallyn
Default RE: Dry Ice For Dents
For dry ice call welding supplyshops. If they are a good and busy shop they usually carry it. It is required to safely weld on containers that held flammable liquids.
Old Nov 6, 2007 | 09:05 AM
Cav Cop's Avatar
Cav Cop
Try a hair dryer and a can of computer cleaner/air to lift the dent.
Old Nov 6, 2007 | 09:21 AM
combat_vet's Avatar
combat_vet
Call a PDR guy, paintless dent removal if you can't source the ice or get it out further.
Old Nov 6, 2007 | 01:35 PM
billfitt's Avatar
billfitt
you could also try a co2 extingusher. according to the myth busters it cooled a 6 pack in secounds!
Old Nov 6, 2007 | 06:07 PM
xxxflhrci's Avatar
xxxflhrci
The dry ice trick is also famous for causing the paint to pop off a few months down the road.
Old Nov 6, 2007 | 06:22 PM
hdpearson13's Avatar
hdpearson13
ORIGINAL: billfitt
Thanks this might be the best information I ve gotten in my 27 years.
Old Nov 6, 2007 | 06:28 PM
xxxflhrci's Avatar
xxxflhrci
ORIGINAL: hdpearson13
ORIGINAL: billfitt
It works great. If you get one of those large extinquishers with a horn shaped nozzle on it, you can cool singles. The nozzle slips right over a can.
Old Nov 6, 2007 | 06:30 PM
anubisss's Avatar
anubisss
I tried the dry ice to no avail. Got it at a liquor store...All the PDR guys I called said they could get dents out of fenders but not gas tanks...
Old Nov 6, 2007 | 06:39 PM
rbabos's Avatar
rbabos
Bodyshop is your only hope. Once a dent forms it leaves ridges around it's perimeter. Nothing short of a hammer and spoon ( spoon shaped metal working tool) will take it out. Even then, filler or the very least high build primer is needed to smooth it. Was a body mechanic in my last life.
Ron
brad75raiders
EVO
18
Sep 27, 2017 01:58 PM
Charlieminchin
Aug 2, 2012 02:57 PM
Shaved Ice
Jun 25, 2010 11:04 PM
drummer3278
Nov 5, 2007 07:27 PM
saltlick
Feb 23, 2007 02:06 AM
