NEED HELP ON GRIP INSTALL?
Old Dec 31, 2005 | 06:41 PM
Harley Al's Avatar
Harley Al
Default RE: NEED HELP ON GRIP INSTALL?
Yeah for Deuce[sm=biker2.gif]
Old Jan 2, 2006 | 05:21 PM
grumpy irish again's Avatar
grumpy irish again
ok did the new switch do any good
I have the sme problem I messed with it and got it working and
after riding for a short time i'm back to the same problem
I have taken the switch cleqar out of the circute checked the switch to see if it
is working and it is ok but I still have brake lights obout ready to rewire the damn thing
only hate to mess with an 04 should not be that much of a problem to replace grips
I had a shop back in the 60's and have worked as a mech. for 20 years this really
pi$$me off help...
Old Jan 2, 2006 | 06:11 PM
06DEUCE's Avatar
06DEUCE
yes you need the new switch. if you did like i did you broke the tip of the switch off. it's hard to see but there is a little tip on the switch that allows the the switch to push in all the way. a new one cost $25.00 . your broke switch will apear to be ok. once you see the new one you will understand. be sure to use a spacer on the brake lever after you install the new switch.
good luck
Tony
sf49ers2005fan
Mar 25, 2017 09:05 PM
jeffscra
General Topics/Tech Tips
Nov 21, 2016 11:55 PM
ultraclassic53
Sep 23, 2014 12:54 PM
cannedham1
May 1, 2009 07:02 AM
lowleveldriver
Jan 12, 2006 08:16 AM
