1985 FXST softail ??
Old Jan 29, 2008 | 12:57 PM
buck2233's Avatar
buck2233
3rd Gear
Default 1985 FXST softail ??
Ihave just purchased this bike from my friend. I don't know much about Harleys. Is this what my bike is FXST softail?? Can someone take a look at tell me more about it. What is the engine size 1200 at 80cc ect...Also I thought the battery was weak cause the motor turns over very slow and sometimes does not even turn and I have to let off the starter switch and hit it again. The battery testedok but I bought a new one anyways and charged it overnight. I plan to try it out today. Is this normal did they not put a compression release anywhere on these. This bike also has a kick starter on it. I was told this was the last yr for that. What is a good place to get a street helmet, Windshield, and sissy bar for the wife? What items should I check on it to verify it is ok for the road. I already changed plugs in it and it runs better by doing this. The oil looks good. WhenI changed the battery I noticed that the seat latch near the gas tank does not have a rubber gromet in it to make it more stable is it supposed to have one?
Thanks
Buck
[IMG]local://upfiles/51752/857E149FA3D443CA9B9066616CD3EF80.jpg[/IMG]
Old Jan 29, 2008 | 01:20 PM
DeJavu's Avatar
DeJavu
Default RE: 1985 FXST softail ??
From your description it would be an FXST. Loose or corroded connectors will weaken the starter power, check, clean and tighten. The kicker can be used alone or with the starter to help it get going. Don't know about the grommet, an applicable manual(HD, Clymer or both)for this model will be necessary with this old a bike. Shovelheads are great bikes, but do require wrenching and TLC to keep them going strong. Good Luck.
Old Jan 29, 2008 | 04:54 PM
LRonHoover's Avatar
LRonHoover
Got a picture?
85 FXST is NOT a Shovelhead.
Should be 1340 CC, V2 Evolution engine.
Good luck with it. I love those Evo's.
Old Jan 29, 2008 | 05:15 PM
HD7585's Avatar
HD7585
The 85 fxst has a starter that most times takes 2 hits to get the evo spinning. Mines been that way since 85. The torque of the starter was increased in later years. If it's something that bothers you...........You can upgrade the starter. I live with it.......So far it's never not started due to the starter...........Good Luck with your new ride [&:]
Old Jan 29, 2008 | 06:21 PM
Stretchman's Avatar
Stretchman
Man, I just bought a FXSTC, and then, I read you sig. (ego deflated)
I actually was getting ready to buy an 85 FXST, but, they turned me down for credit. Ended up waiting 13 years for a Harley, and another nine for a softail. Never should've waited. I love the bike.
Stretch
Old Jan 29, 2008 | 08:13 PM
wbogley's Avatar
wbogley
Very nice evo! I really love the older bikes. Is that a puddle of oil under the tranny in the picture?
Old Jan 29, 2008 | 08:45 PM
byersmtrco's Avatar
byersmtrco
All true. I had an 84 Shovel with the same Hitachi starter arangement. Usually lit right off when cold, but hot,
two times.
85's were cool. 4 sp, kick/elec (chain . . . or was that 84 FXST only?) They never did put a Shovelhead
motor in a Softail frame. They did however have a "modified" Duo/Super/Electra Glide frame in 1985 & 1986
with an Evo motor and 4 sp w/kick & elec. The FXWG. Truely the last of it's kind.
They've been tring to come up with something that cool ever since. Some came real close . . . Some
failures (Rocker . . . need I say more)
Have fun with your Evo !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jan 29, 2008 | 10:29 PM
buck2233's Avatar
buck2233
3rd Gear
ORIGINAL: wbogley
Yes there is a puddle but that is not from the bike it is from my 2000 Ford Powerstroke.
Thanks for the NFO
buddman04
Oct 13, 2014 08:39 PM
jbudd3
General Topics/Tech Tips
Sep 20, 2014 06:44 AM
Carnutter5
Oct 22, 2012 11:21 AM
Eightball52
Oct 14, 2012 10:03 AM
cowboyfxst
Jun 26, 2007 10:34 PM
