Advise on Removing Tank Bib
Old Feb 2, 2008 | 11:19 PM
05 HD Deluxe's Avatar
05 HD Deluxe
Default Advise on Removing Tank Bib
Have a question on removing the leather tank bib on the deluxe. I see the screws on the end under the seat. How do you remove the end under the dash ? Want to put a chrome dash extention on. Also how does the extention attach under the dash ?
Old Feb 2, 2008 | 11:27 PM
conroskie's Avatar
conroskie
Default RE: Advise on Removing Tank Bib
I don't know if the crome extension goes under the dash or not, but i'm sure it does... I replaced my plastic bib on my 03 heritage with a leather one and all I had to do was take out the screw under the seat and loosen the nut by the speedo and slip it out. Be careful when you tighten the nut back up as to not over tighten it and crack your dash! Chuck at ChicagoHD gave me this advice and I thank him for that since I am one of those guys that would do such a thing. Very simple...
Old Feb 3, 2008 | 12:23 AM
08fxstb's Avatar
08fxstb
On my '08 Night Train all I did was remove the screw under the seat then take the bolt off the speedo. The top part of the bib wasn't screwed down or anything. It took maybe a minute to swap out the stock bib to a leather one.
Old Feb 3, 2008 | 07:49 AM
darkman's Avatar
darkman
Ditto 08!
Old Feb 3, 2008 | 08:20 AM
1BadTrain's Avatar
1BadTrain
Hammer and chisel!
Old Feb 3, 2008 | 10:41 AM
05 HD Deluxe
Thanks for the tips everyone. Think I will pass on the hammer and chisel
Old Feb 4, 2008 | 08:06 PM
hdsd05's Avatar
hdsd05
Dude use the hammer and chisel. Gives the bike that personal touch. Like everybody else said just loosen the speedo nut. If you take it off completely be carefull not to loose the washers, 1 flat and 1 split ring. Don't ask me how I know.
Old Feb 4, 2008 | 08:11 PM
1996Softail's Avatar
1996Softail
When I swapped my leather dash for a chrome oneI had a problem with the chrome one moving from the vibration no matter how tight I made the speedo nut and it chipped the paint on my tank. I went to Home Depot and bought a thin strip of velcro and put it on each side of the tank and dash and that solved the problem might want to try that before damaging the paint just my advise
Old Feb 4, 2008 | 08:32 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
ORIGINAL: 1996Softail
I went to Home Depot and bought a thin strip of velcro and put it on each side of the tank and dash and that solved the problem might want to try that before damaging the paint just my advise.
Thanks for the tip, collected a bunch of parts for winter and I'm in the process of doing my winter 'projects'and that's just one on the list.
Old Feb 4, 2008 | 08:52 PM
05 HD Deluxe
Nice tip Thanks
cecil1
Apr 8, 2011 02:07 PM
jokr
Dec 22, 2009 09:41 AM
BIG Y 2014
Jan 7, 2008 08:11 AM
birdie
Apr 8, 2007 12:14 AM
jdduvall
Feb 25, 2007 04:32 AM
