Odometer button stuck...
Old Mar 28, 2008 | 08:01 PM
WARG's Avatar
WARG
Default Odometer button stuck...
Went out to the garage yesterday and I noticed the light on my odometer/trip meter was on and the mileage was showing. I had checked themileage the night before, so I guess it stayed on all night. The ignition was off, so I turned it on and off and the light went out. I pushed the button several times with the ignition off and it operated correctly (stayed on about 5-10 seconds and went out). Maybe the switch just stuck, I had washed the bike the day before. Anyway, I hooked up the battery tender and in about 45 minutes it was back to full charge and life is good. Bike fired right up.
Anyone else had their odometer button stick or do this?
Old Mar 29, 2008 | 08:09 AM
WARG's Avatar
WARG
Default RE: Odometer button stuck...
anyone...
Old Mar 29, 2008 | 08:21 AM
Strgzr's Avatar
Strgzr
Tried both of mine. Lite went off after 5 secs on both for what it's worth.
mike
Old Mar 29, 2008 | 08:24 AM
Strgzr's Avatar
Strgzr
Hey Warg,
Your bike ride any different with wire wheels over the solid wheels. I'm asking becuase I wonder of the solid wheels can cause a "gyro effect" due to weight.
Mike
Old Mar 29, 2008 | 09:00 AM
WARG's Avatar
WARG
Thanks, Probably just stuck. No biggie. I will just have to make sure it clicks off in the future.
The wire wheels feel normal b/c I have never had anything else.
Old Mar 29, 2008 | 01:54 PM
tmitchellof PG's Avatar
tmitchellof PG
I think the reason that you are not getting any responses, is that the odometer button sticking is not a common problem.
Tom
Old Mar 30, 2008 | 04:40 AM
kato1964's Avatar
kato1964
ORIGINAL: tmitchellof PG
Tom
+1
I've never experienced this problem on my Fatty. If it does occur again, maybe a quick squirt of good ole WD-40 will solve the problem. (??) Just an idea.
Old Mar 30, 2008 | 10:12 PM
WARG's Avatar
WARG
Well I have pushed the button 20 or 30 times and it works correctly everytime but once, so I'm not really worrying about it. If it starts to happen frequently I will repace the switch. Shouldn't be too hard.
Beckzilla
Jun 20, 2013 02:43 PM
Dgaroutte
EVO
11
Jun 12, 2013 09:18 PM
usaztec66
Apr 15, 2011 02:28 AM
Bill-FXDF
Jun 14, 2009 05:02 PM
chefbayliss
May 20, 2008 02:05 PM
