DIY Cheap Mods
https://www.hdforums.com/forum/dyna-...ml#post4228103
It doesn't take long, it's inexpensive and it's soooooo much more comfortable.
It is important that you make the cuts the way I have drawn them. This way, the direction it takes to remove the backrest is exactly the opposite direction of the pressure while it is in use.
The Dyna guys can do this too.
While I sat there i began to despise my tail light more and more with each passing moment. *shrug* I dunno... you know how that happens right?
I decided to do something about it... I have wanted to install something with integrated turn signals for a long time... but the integrated signals for HD seem incredibly lacking asthetically to me.
I much prefer something like the Ducati Monster,
dont look at me like that! Its MY bike!
But it wont just mount up to this ugly plastic POS
Thinking caps on!
Once you remove the ugly effin hunk of plastic, slap a piece of cardboard up there. Make a couple of 1 inch notches so the cardboard can slip down past the point where the lower tag panel attaches to the tail light housing.
Flip the housing around and trace the outer edge. Cut out your template and.... voila!
Grab some sheet metal... 5-7 bucks at home depot
This pan will eat up 8 inches... so you can get three of these out of a 12x24 sheet. I know this isnt very thick... just mocking this idea up and it could be cut and trimmed easily with snips. I will get something thicker for the final pan.
Clamp the template down on an 8x12 inch piece of your sheet metal and trace around it. You probably have super cool metal working clamps... I got these all purpose "I need to clamp wood together for the glue to dry" clamps... so I used them.
Use the snips to cut out around your line... but stop at the bottom of the line... you will see why in a second.
You need these little ears to fold up. You will drill two holes in each to mount your new pan.
Yeah some masking tape on the fender to prevent scars when you are fitting the new pan is EXCELLENT advise. I happen to have a set of denim black in a box waiting on me to install so I didnt really care as these will end up being painted as well. But anyway... slap some flat black paint on this and you have something you can mount other lights to.
With this is mind I grabbed a light I had picked up for the sporty just to see something blinky back there. Drilled a couple of holes, shoved it in and poof! New light!
Yeah it looks like crap... of course I would recess it into a hole so it mounted flush.... but its not the light I will end up with anyway. And again, this is just mocking up an idea.... I will get some thicker steel and use this as a template to make the final product.
<--- I dont know WHY this freakin picture wont show up when I read the post... but in case it doesnt for you either... here is the direct link http://lh5.ggpht.com/_JHCRXNuv84Q/SU...k/template.jpgThis should be self explainitory.... you want a piece of sheet metal shaped like the black lines... to scale with your fender of course.
Bend it on the red lines... Ta Daa!
Drill a couple of holes for the mounting bolts.... and now for the tricky part... either find some low profile nuts to go between the bracket and fenderwall... or you can try to reuse the ones from the stock plastic mount. I went with low profiles I found in the specialty fasteners at my local ACE hardware.
Im sure there is a better way... but this is me getting one step closer to integrated turns in a tail light and ripping the stock mushroom stalks off my rear fender. I think it will clean up the rear end real nice.
Let the bashing begin!
Existing door opener
Old aquarium light hood switch with rubber boot
Spare computer cable
Cost $0.00
Soldered some wire between the switch contacts and the button
Punched a hole in the bag, screwed the switch on, stuck the opener to the inside and booted it.
P.S. If you use a 5 terminals relay, just leave the 87a unused. You can also wire a momentary switch to join the relay solenoid circuit. I prefer high beam switch because it is easy to hit.
