DIY Cheap Mods
But for those that have this problem I have a $10 answer.
Go to your local hardware and get 2 shaft collars, 1/4 inch interior diameter, 1/2 inch exterior diameter. These are in the standard packs on the wall of nuts and bolts the stores buy. Basically, these look like a thick washer with a small hole on one side in which is threaded an allen bolt headed screw. The screw twist thru the body and pushes against whatever is inside. This holds the collar on to a bolt.
Next go to local dealer with the collar and find a 1/2 inch diameter chrome bolt cover that almost slides over the collar. Again, standard size thing these guys sell to hide engine bolts.
Then all we do is remove acorn nuts for one last time from bolts, slide on and lock on shaft collar. and then, using a demmel or small file, trim the interior of the bolt cover until it slides firmly over the locked collar.
Last step, put allen wrench for collar in tool pouch.
If there is any interest I will take a few pics and send the to Citoriplus. I have had no luck reducing or posting lately.
This idea gives a clean bolt cover that can be quickly removed with tools, but is otherwise secure.
Any thoughts post or email me.
Mike
Got these signals off of ebay.
Needed a longer 3/8" bolt to mount these to the very rear of the strut. Also used a 3/8" nut that cost 10 cents as a spacer as the fancy chrome one I bought was too wide and I don't ahve a machine shop here at home. Took off the old super lollipop signals and took off the connectors from the taillight. Had to add a little bit of wire from the old signals to the new ones so it would reach the plug in the taillight. Crimped it together with butt connectors and ran the wiring. Plugged it in and off I went. The longer bolts I got for the mounting of the signals were free from a custom shop near here. $20 plus and outrageous $12 to ship 2 miles as the guy would not let mne pick it up. Still a deal for relocated signal.
$40 attitude stick made by shoptroll (a banned user who is on a nother site now) I already ahd the sideplates so I had him fashion the style of sissybar I wanted and paint it black. Shipping put it jsut over $50 as he lives across the country, but another nice cheap mod. To see pics search my threads of if you want more info feel free to PM me.
Danny D
chrome, stainless, blackened......good site quick ship and easy to navigate
http://www.boltdepot.com/Chrome-nuts-and-bolts.aspx
Thanks for the info on boltdepot.com. I added them to my favorites.
Danny
As you put more and more miles on your softail, if it does not have a simple thing installed, the shifter will get tight bacause of grit and rust and lack of fresh grease.A quick fix is to take it apart and clean and regrease....or....
Take it apart and clean it.
Drill a #3 hole in the frame tube where the forward controls "shifter splined shaft" goes through.
Tap that hole with a 1/4"-28 tap and de-burr.
Install a 1/4"-28 zirc fitting.
Be sure to get a very short threaded fitting or you will need a washer....like me...LOL
You can go one step better on this and grind a small groove around in line with the fitting. It's not mandatory, but makes it easier to put the grease in.
Sorry, no pics yet. My digi cam took a crap and my phone cam sux!
